What difference lift??
Old Nov 23, 2001 | 05:39 PM
1CAMWNDR's Avatar
Default What difference lift??
Lets assume stock heads, long tube headers, Mufflex 3.5" single in and single out, stock intake. With duration of 224*/228* and a 112* LSA with a 111* IC; what would be the power differences between .530"/.540" lift and the more radical .566"/.575"? Are the bigger lift cams worth it? How often would I need to cahnge valve springs?
<img src="images/icons/confused.gif" border="0">
Old Nov 25, 2001 | 12:35 AM
1CAMWNDR's Avatar
Default Re: What difference lift??
Anyone have info on how much more power the .566"/.575" cam will have over the .530"/.540"? <img src="images/icons/confused.gif" border="0">
Thanks <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 25, 2001 | 08:09 AM
2000 Camaro SS's Avatar
I'm sorry but I can't tell the diffidence on power but with the .566"/.575" cam you would HAVE to get head work done and double springs. I would suppose if your heads would flow enough air the bigger would be fast but.... (you would need head work) If you use the 530"/.540" can you can use good after market springs. Both cams look good for either Nitrous or forced induction. I just bought a Lunati 221/224 .558 .560 @ 114 and I will be using Copm Cam 941 springs. With my lift I am told to change springs every 20,000 miles or sooner.
Old Nov 25, 2001 | 08:23 AM
Patrick G's Avatar
LS1 Tech Administrator
The power difference will be pretty negligable with stock heads. With ported heads (that will see more of a flow difference at high lifts), you might see 3-5 hp difference between the two cams, but honestly...on stock heads, you'll be just as fast with fewer valvetrain problems with the lower lift cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 26, 2001 | 10:57 AM
1CAMWNDR's Avatar
[quote]Originally posted by Patrick G:
<strong>The power difference will be pretty negligable with stock heads. With ported heads (that will see more of a flow difference at high lifts), you might see 3-5 hp difference between the two cams, but honestly...on stock heads, you'll be just as fast with fewer valvetrain problems with the lower lift cam.</strong><hr></blockquote>
That is just what I wanted to hear!!
Yes, the cam may be used with forced induction in the future. (ProCharger most likely, but I keep thinking about a turbo....) I like the fewer valve train problems--I will step up to Comp 918 or 941 springs, whichever Comp suggests. Heads might get a mild clean-up by myself.
[ November 26, 2001: Message edited by: 1CAMWNDR ]</p>
Old Nov 26, 2001 | 06:15 PM
Chris Spiess's Avatar
If you're planning to get the heads cut for the 941s, just go ahead and cut them for 987s, a double spring. It would be more reliable in the long run.
Old Nov 26, 2001 | 06:33 PM
[quote]Originally posted by spiesscj:
<strong>If you're planning to get the heads cut for the 941s, just go ahead and cut them for 987s, a double spring. It would be more reliable in the long run.</strong><hr></blockquote>
you don't need to get your heads cut to install 941 springs.
Old Nov 27, 2001 | 10:38 AM
1CAMWNDR's Avatar
Yeah, I thought the 941 and 918 did not require the heads to be cut.
