Where to find air fitting that threads into plug hole to change valve springs?
I need to get a air compressor fitting that threads into the spark plug hole to put preassure on the valves while i change out the valve springs,where can i get one? What are they called?
Jegs has them. It's called an airhold adapter, p/n 892-8870 (14mm) or 892-8871 (18mm). $10.69 each. Hope this helps.
Thanks for the name lol never knew it. I found some at O'Reilly's for $4.99 for both <img src="images/icons/smile.gif" border="0">
