BIG PROBLEM!! read and help if possible please
Old Nov 25, 2001 | 12:01 AM
minty's Avatar
Default BIG PROBLEM!! read and help if possible please
well guys heresthe deal...i was driving around not beating on the car and the car all of a sudden at 45 mph starts to bog and shake even when i wasnt touching the gas pedal....we get it home and take out the snap on computer and cylinders 5 and 7 are off the board with misfires...we pull the plugs....theyre covered in fuel....no chance to do a compression test yet...but what do you guys think the problem might be....any help is GREATLY appreciated, we will be wrenching in the meantime to see if anything else is broken....will check in soon, ideas NEEDED!!!
thanks
Old Nov 25, 2001 | 12:05 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: BIG PROBLEM!! read and help if possible please
If your plugs are covered with fuel, then you are not getting any spark. Check the plug wires, check the coil packs, check the pack harness connection.
I'm betting on the wires being faulty or loose based on what you are describing.
Tony
Old Nov 25, 2001 | 12:06 AM
Jacobi's Avatar
Is it possible the wires were reversed cause them to fire out of order??? If not, hook up on ohm meter to the wires...
Old Nov 25, 2001 | 12:09 AM
minty's Avatar
plugs and wires were checked for all that and there is spark....that was the first thing we checked.....
Old Nov 25, 2001 | 12:10 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Any SES lites?
Y'all change anything? Lately?
Old Nov 25, 2001 | 12:12 AM
minty's Avatar
the check engine light was flashing a few seconds after the bogging started....
Old Nov 25, 2001 | 12:20 AM
LS1Tech Co-Founder
Flashing can mean major misfire action going on.
I wonder if your MAF is messed up. Those little wires are pretty sensitive.
Good nite I will check the thread tomorrow morning.
Old Nov 25, 2001 | 12:26 AM
ChrisB's Avatar
Do you have access to autotap or any means of logging it? Specifically check for the MAF reading - this is your primary determinant in fuel metering.
Do the plugs/cylinders even get warm?
Chris
Old Nov 25, 2001 | 12:27 AM
2quick4u's Avatar
minty,
Your MAF may have suffered damage from the styrofoam block incident. Try running in Speed density mode and see if the misfires go away.
Old Nov 25, 2001 | 04:10 AM
minty's Avatar
wish that was the case but afraid not guys, i tried a different MAF and to no avail....oh well, the car is gone for the year now....
Old Nov 25, 2001 | 06:18 AM
c4c5specialist's Avatar
HI there,
Was the misfire code the only code when checked???
besttoyou, c4c5
Old Nov 25, 2001 | 06:21 AM
cantdrv65's Avatar
Valvesprings? What's the odds of breaking two?
Old Nov 25, 2001 | 07:03 AM
Dustin Butts's Avatar
Could a couple of injectors have decided to take a dump all at the same time? I had one do that. Started running like a miss, felt real flat in one cylinder. Pulled the plugs and number 5 plug was all wet with fuel. No SES light though. Replaced the injector and no more probs. What mods do you have? Running a big dose of dry N2O?
Old Nov 25, 2001 | 08:29 AM
TA/30th 1002's Avatar
Let’s see here. 5&7 are next to each other mechanically. They’re getting gas/spark. Me thinks it's time for a compression test. Initial prognosis; head gasket.
... 1002
Old Nov 25, 2001 | 02:30 PM
minty's Avatar
guys, i believe it is a head gasket, there is coolant in the oil so what the hell else could it be...looks like i will have some work ahead of me.....thanks for the help...ive got it from here....and no there was no nitrous on the car, we were going 48 mph at 2200 rpms when this happened......
Old Nov 25, 2001 | 02:38 PM
BIGBOS's Avatar
holy crap....I didn't even see this thread until this morning...hope everything works out...
Old Nov 25, 2001 | 09:59 PM
cantdrv65's Avatar
[quote]Originally posted by TA/30th 1002:
<strong>Let’s see here. 5&7 are next to each other mechanically. They’re getting gas/spark. Me thinks it's time for a compression test. Initial prognosis; head gasket.
... 1002</strong><hr></blockquote>
Dam, that makes alot more sense than two valvesprings!!
Old Nov 26, 2001 | 09:11 AM
CMNTMXR57's Avatar
He's got a "milkshake" for oil which means head gasket went bye bye. <img src="images/icons/smile.gif" border="0">
