which cam should I go with?
Old Nov 25, 2001 | 08:40 PM
Red02LS1's Avatar
Default which cam should I go with?
I'm thinking of doing a cam next spring. I have no idea where to start. Right now I have 327RWHP and 344.7 torque w/ only a lid and catback on my Z28. I plan on leaving my heads stock. I want a cam that has good driveability, but gives decent power. I dont really want to rev my motor much over 6400 or so. I dont mind if it has a slight lope at idle, as long as I dont have to do reprogramming, or tuning. What else do I need to get with the cam. I know I'd need new springs, and pushrods, but what else?? And what would be an estimated total cost? I have someone locally here that could help with the install. I've rebuilt an old ford 302, and did a cam on that. I had a .472, .496 lift and 214, 224 duration on that motor, and I loved the way it sounded at idle.
Old Nov 25, 2001 | 08:59 PM
LJ_Z28's Avatar
Default Re: which cam should I go with?
Is your car an M6 or an A4???
Old Nov 25, 2001 | 09:01 PM
Red02LS1's Avatar
M6, car in sig
TA_2001's Avatar
Click on See the Results..
http://www.ls1info.com/camstats/
This is recent info.. if you get a cam
install your performance here.
This info will give you some ideas about
what to expect from diffrent vendors and
or setups
Old Nov 25, 2001 | 09:02 PM
BIGBOS's Avatar
Go with a C1 or T1 from MTI if you want a good amount of HP up high...
I got a custom grind COMP CAMS cam...
222/222 .563/.563 112lsa...
Gave me 24rwhp...
Old Nov 25, 2001 | 09:03 PM
LJ_Z28's Avatar
[quote]Originally posted by BIGBOS:
<strong>Go with a C1 or T1 from MTI if you want a good amount of HP up high...
Gave me 24rwhp...</strong><hr></blockquote>
Completely agreed... <img src="images/icons/grin.gif" border="0">
Old Nov 25, 2001 | 09:28 PM
Red02LS1's Avatar
what about the comp 216/220?? How much would I gain from that??
Old Nov 26, 2001 | 12:03 AM
MARO-KEEN's Avatar
LS1Tech Sponsor
i agree with c1/t1 both very good cams.make good power and great for the street.
