Comp 212/218 or 216/220 users...
Old Nov 28, 2001 | 01:27 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Comp 212/218 or 216/220 users...
What rpm are your shift points at (A4) or where do you shift (M6)? I’m looking at one of these two cams to use with stock heads and just MACs + the common bolt-ons and I’m wondering where you guys are shifting. I know I should go based on a dyno chart, but I’ll just like to get a good idea of where everyone else is at.
Old Nov 28, 2001 | 04:10 PM
LiquidSnake's Avatar
Default Re: Comp 212/218 or 216/220 users...
A4 with stage I style heads with Cranes and Vig 2800+Mac/ORP/Borla.6400 rpm (5900-6000 with NOS)
212-218 Cam
Old Nov 28, 2001 | 04:15 PM
Plan B's Avatar
M6 with stage 2 heads 216/220 I shift at 5800 - 6000.
Old Nov 28, 2001 | 04:27 PM
RPM WS6's Avatar
Thanks guys. <img src="images/icons/smile.gif" border="0"> Keep 'em coming!
Old Nov 28, 2001 | 06:16 PM
BFreeZ28's Avatar
216/220, A4 SY3500 3:73 gears only shifts at 6000 each time I have some fine tuning to do as soon as someone in my area becomes LS1 Edit knowledgeable!!!! *COUghFIREBALLcOUgH*
Old Nov 28, 2001 | 07:31 PM
TRehr's Avatar
My shift light is set at 6500 (I have a custom ECM program by Ed Wright). My star stage 2 bites hard at that rpm and my 4:10 seem to like it too!
Todd Rehr XLRATE
405.8 rwhp / 384.6 rwtq
'99 30th Anniversary TA WS6 (#1118)- M6: MTI lid , K&N, FRA, Fernco Coupler, TB bypass, Ported and polished TB, LS6 Intake, Cooling Fan Switch, Mac Headers and custom Y pipe (C&L high flow cats and FM collector), McCord 2nd Gen Power Cutout, SLP underive Pulley, MORE stage 2 CNC heads (2.08/1.60) & Comp Cam (216/220 - 525/532) & top end kit, Ed Wright programming, MAFT, KnockOut Box, Line-Loc, Harlan Shift Light, Pro5.0, Star Stage 2 clutch, 4:10s, Boxed LCAs, Nitto DRs(on 17" 30th rims).
[ November 28, 2001: Message edited by: TRehr ]</p>
Old Nov 29, 2001 | 07:40 AM
RPM WS6's Avatar
Wow, sounds like you guys shift pretty high! I thought with these cams and their relatively low lift numbers that a shift in the 6200 to 6300 rpm range would be good. What about if you had stock heads? Would 6200 be good, or should I try 6300+?
