Dont Buy Into It!!!
#62
Originally Posted by SUTTERERMAN85
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
sorry guys had to through it. i have always ran 10w40 and not one prob. 10w40 is not much heavier than than 10w30. and in now way would cause what you are describing.
I am now unsure as to what it is except that after that oil change the motor got a lot louder, lots more tapping. I am pulling the valve covers tomorrow to see whats up.
#63
Originally Posted by Black FormulaLs1
if Fram suregrip oil filters are junk * thats what i run* then what is the better oil filter? and i run M1 10w 30 in my bird..is there something better? i used to run royal purple 10W30 but now not so sure..can anybody help here? on my 2nd motor and cant afford a 3rd right now...
#64
Originally Posted by 97F1R408
You could seriously have changed your oil and put bar chain oil in and you wouldnt have developed this issue. Its funny how people lie to themselves knowing in the back of their minds what probably really happened. Usually this would happen after getting an oil change at a shop and the person would then go back and try to scam a new engine out of them. And how many miles does this car have again??
73K miles. Yo uare right, it is senseless and im not sure if the oil change did it or what, but nothing else happened to it in that half hour timeframe. Quiet before, noisy after. What was I supposed to think did it?
#65
For me: M1 0-40W, psi stays above 50, sound is comparable to the 30W.
BLKWS.6 you make it sound like you switched from ****-eaze to vegetable oil. Also sounds like a knee-jerk over-reaction to an unrelated probelm.
I'm gonna ask the obvious...you said you just added 6 qts. after changing the oil....did you bother to check the level?
#66
#67
#68
OKAY IM A 'TARD!!!!
I did NOT KNOW the LS1 motors have roller rockers in them. That is what I am hearing, it happens most 1-2000 rpm off-throttle. Dad listened to it, says its no quieter or louder than the day I bought it. Anyways, My 5.0 had RR's (upgraded) and it sounded just like this (only louder, it had roller tips too). Sorry for my retardation. I will run this 10-30 M1 for 2-2500 miles and then go 0-30 GC and STFU. Sorry
OCD+Ignorance > Me
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#69
Originally Posted by BLKWS.6
OKAY IM A 'TARD!!!!
OCD+Ignorance > Me
#70
LS1Tech Sponsor
I just think it was funny that you really fought that the thicker oil made your engine louder. From the sound of it the engine was dead silent,you did an oil change and it sounded like all the bearings spun.You were mad!! Then you admit that it is the same as it was before.... Too funny.
#71
I HATE FRAM, my dad had one jack up on him once. My mechanic blew their guts out every time in his 8,000+rpm dirttrack cars. He went with WIX and never looked back.
#72
PS, I had a crown vic this EXACT thing happened when I used 15-40 Shell rotella. Put in 10-30 GTX and it was fine forever more.
i didnt know that crown vics ever came with diesels...cause shell rotella is diesel mtor oil...
congrats on not having a problem with your T/A
#75
Originally Posted by wolfy
something about this post boggles my mind...
And I never knew that LS1's were european, because 0-30 GC is a european formula.
Shrell Rotella 15-40 is about the highest concentration detergent oil out there. My last TA was run on it (170K mile LT1) and I had to do 500 mile oil changes for 2500 miles, each time i would dump almost pudding-like crap from the filter. After 2500 miles, cleared up. After driving millions of miles (literally) and using dozens of oils, my dad came up with a few thoughts. Quakerstate sucks, M1 and Amsoil are cool but not worth the $$ in the long run with the cars he used (5.0 and 4.6 crown vics), and Shell Rotella produced teh cleanest crank case upon tear-down inspection. Fram filterss suck and WIX do a great job.
Yeah, I guess the outcomes is somewhat expected
#76
OCD>ME
#77
Originally Posted by mvvette97
that's right about the Rotella but put it in an engine that has a **** load of miles and see what happens. If it has 15-40 from the git go it would be fine but if not then using 15-40 is BAD! You will clean everything including the rings. Then you have an oil burner
My LT1 didnt use a drop at 170K miles. That is as far as MY PERSONAL EXPERIENCE with rotella T goes.
#78
Wix or any of the brands that are renamed Wix filters... (napa gold, mobile1, ect..)
