Dont Buy Into It!!!
the 0w30 was the german castrol, 0w40 was M1
10w30 etc was cheap dyno oil that i ran in my stroker motor.
Apparently my dumb *** didnt know LS1's had RR's stock. My dad listened to it 5 seconds and said "those are your roller rockers...you know...your 5.0 does that only 2x as loud? sounds the same as when I heard it on the dealer lot" I felt like a 'tard
Yeah, it makes a tapping sound 1-2000rpm when I come off the gas or when I jig the gas. all 16 sound the same. Just RR's and I didnt know it had em'
. But this is no different than many of the other threads where folks swear to something that when empirically checked shows absolutely no variance.Don't get so hung up on viscosity numbers, like flow numbers, they are only a reference. Look at some of the posts by Patman, and some of the posts on BITOG if you want to understand the numbers behind the numbers.
As for me, I run 5W40 M1 Diesel Truck formula in my Z06. On anything with a flat tappet cam, or for inital break in these days I run Rotella. I'd run German Castrol, but I've had really good luck with M1 in a bunch of motors with a LOT of miles on them (320K on one) in fact.
Guys, the internet can be a great help if you read and research a bit. But, you also have to use the brain that God gave you first.
As usual well said sir..
Or does the OP have RR on his car?
