P/V clearence w/ this cam and heads?
right now I have the 225/225/589 112 with PRC ls6 stock valves, milled 30 thousands. I want to install the TSP torquer 2 cam, 232/234 595/598 112. Will this cam fit? I've talked to the guys @ TSP and they said it'll probably be ok. I really don't want to check it. Anyone know if there will be any P/V issues?
thanks
thanks
And remember: just clearing it isnt' enough, unless you wanna shift at some pussified RPM before your setup even peaks. You want it to have the recommended clearance.
Intake:
preferred .080"
acceptable .060"
Exhaust:
preferred .100"
acceptable .080"
And no, I have no idea why more on the exhaust than intake.
Intake:
preferred .080"
acceptable .060"
Exhaust:
preferred .100"
acceptable .080"
LS1Tech Premium Sponsor
N4cer is exactly right, checking p/v is very important.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Intake:
preferred .080"
acceptable .060"
Exhaust:
preferred .100"
acceptable .080"
Intake:
preferred .080"
acceptable .060"
Exhaust:
preferred .100"
acceptable .080"
The moral of the story, you'll need to check it for sure.
Ben T.
