getting rid of false knock
Old Nov 30, 2001 | 08:10 AM
LS1[CHEVY]'s Avatar
Default getting rid of false knock
I am getting false knock from what I think is my cutout vibrating the whole dame car a WOT. What can be done to stop this? Also just in case . How do you stop your exhaust from banging under the car on hard acceleration?
Old Nov 30, 2001 | 08:19 AM
TRehr's Avatar
Default Re: getting rid of false knock
See Nineball (Tony) he has a kick *** product he calls his knockout box.
http://users.ev1.net/~ynot_dv8/KOBox.htm
Todd Rehr XLRATE
405.8 rwhp / 384.6 rwtq
'99 30th Anniversary TA WS6 (#1118)- M6: MTI lid , K&N, FRA, Fernco Coupler, TB bypass, Ported and polished TB, LS6 Intake, Cooling Fan Switch, Mac Headers and custom Y pipe (C&L high flow cats and FM collector), McCord 2nd Gen Power Cutout, SLP underive Pulley, MORE stage 2 CNC heads (2.08/1.60) & Comp Cam (216/220 - 525/532) & top end kit, Ed Wright programming, MAFT, KnockOut Box, Line-Loc, Harlan Shift Light, Pro5.0, Star Stage 2 clutch, 4:10s, Boxed LCAs, Nitto DRs(on 17" 30th rims).
AJH LS1 Z28's Avatar
Tony (Nineball) has designed a False Knock eliminator. You may want to get with him.. He can get you these very quickly and they work VERY well...
Knock it out!!
Old Nov 30, 2001 | 08:20 AM
DAMN!! Todd beat me too it!! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 30, 2001 | 08:27 AM
LS1[CHEVY]'s Avatar
Is there any danger is using this device while also using nitrous?
Old Nov 30, 2001 | 08:43 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Yes, there is possible danger if your engine is suffering from real knock while spraying nitrous. That knock sensor setup would help save your motor under a nitrous detonation.
Personally, I do not recommend my product to guys running nitrous or boost, but some of them have purchased it anyways. As long as they know 100% they are suffering from false knock, I guess they feel confident about using it.
Thanks for the promotion Todd and Anthony! <img src="images/icons/wink.gif" border="0">
Tony
Old Nov 30, 2001 | 10:00 AM
LS1[CHEVY]'s Avatar
So if I eliminate the knock being real knock then I should be ok using the knock out box? Ill do all the testing this weekend . Would you think I should have to use better that 94 octane for the tests? Everyone says 100octane race gas has to be used.
Old Nov 30, 2001 | 10:59 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I would always use 100-104 Octane race fuel to test for false/real knock retard. If you see KR on that stuff and you are not running lean, then its most likely false knock. If you run that race fuel and your knock retard disappears, you are having real knock.
Yes, once you determine you have false knock only, then the box will be okay to use.
Tony
Old Nov 30, 2001 | 11:10 AM
LEO's Avatar
LEO
Hello - Tony "MR. I am SOOO Special that I have to have my name highlighted in red so I can stand out from the rest of the LS1tech crowd" Whatley, what's up? <img src="images/icons/grin.gif" border="0">
I would like to try out your product the next time I see you @ MTI, if it's possible. <img src="images/icons/grin.gif" border="0"> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 30, 2001 | 11:53 AM
cablebandit's Avatar
hmmm false knock....do you think when I'm revving to 5 grand in the staging beams and getting 2 degrees of KR that its false? <img src="images/icons/grin.gif" border="0"> This did actually happen to me last weekend with my m6
Old Nov 30, 2001 | 05:19 PM
LS1[CHEVY]'s Avatar
Anyone else with a catback and cutout having this problem?
Old Dec 1, 2001 | 09:54 AM
LS1[CHEVY]'s Avatar
ttt
Old Dec 1, 2001 | 10:06 AM
TRehr's Avatar
I didn't get false knock until I install the headers & custom Y-pipe. I think the extra exhaust noise (vibration) from the headers in the engine bay is to blame. <img src="graemlins/gr_cry.gif" border="0" alt="[whiner]" />
Todd Rehr XLRATE
Old Dec 1, 2001 | 10:32 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Hey Leo, Shaddup! haha
I didn't start getting bad false KR until I tried running with basically open headers (just a pair of bullets off the header extensions) when I was getting ready for the Bowling Green event a few months ago. I was seeing about 3 degrees KR with that loud exhaust setup, which is why I learned about the sensors and came up with a better design for desensitizing them. Didn't really plan on selling the item, but people kept emailing me wanting them.
Tony
