6.125" rods..anybdoy use them??
<strong>THE STOCK RODS ARE 6.125</strong><hr></blockquote>
no they are not
6.098"
I know ARE has built quite a few motors with the 6.125" rods. Pretty sure PSJ has/had them
I know they are being used, if i decide to get pistons and rods from ARE for the build up i'm going that route <img src="images/icons/smile.gif" border="0">
I had a set of forged Dyer 6.125 rods. Perhaps check with Nick @ ARE I traded them in to him.
JE makes pistons that work with those rods. I had a set.
Stock is 6.098 like Harlan said.
Man we need to get the FAQ up.
Aftermarket pistons tend to be cheaper if they are not full custom. With JE, I believe that the comression height necessary for 6.125 rod, stock or 4" stroke, and stock bore is not considered custom, and will save you about 3-400$ for a set.
I have a *really* nice set of Oliver billet I beam rods left over from another project, but they are 6.000". I will need custom pistons to run them (.125 more compression height than a 6.125 rod), but since I am thinking stock stroke, the Rod/Stroke ratio should remain ooooookay...
ThunderRacing has the stock bore/stroke/compression height/deck height info on their website in the Piston area.......
Chris
