Need help-car failed emission test
1. make sure the car is fully warmed up.
2. New oil in the crank case?
3. new plugs?
4. The ported MAF "should" lean it out a bit and that will help you some.
5. Set your idle up just a bit..(use a piece of tape, adjust the screw, etc...)
6. Your O2 sensors could just be going bad. LOTS of times when headers are added to a car.. the sensor go bad. This is usually because they got some "bad" substance on them while they were out of the car. Such as ANYTHING with silicone in it, or grease ... man it seems almost ANYTHING will contaminate them. If you can install your rear O2 sensors in the front and give it a go.
They also make an additive that will ower your emissions. It really does work. About any parts house sells it.
Good luck.
Make sure your AIR pump is running, even if you have to jumper it on - secondary air reduces HC. Perhaps an oversized pump? Remember, it's reading percentage, so if you double the airflow out the tailpipe, you cut your HC in half...
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
<strong>Emissions tests??? I didn't even know we had that in Texas. I've never had it.</strong><hr></blockquote>
The big counties (Tarrant, Dallas, Harris, etc) and surrounding DO have sniffer testing. The smaller counties do not.
-Andrew (smaller county resident - we let all our crap blow in to Oklahoma <img src="images/icons/grin.gif" border="0"> )
[ December 06, 2001: Message edited by: TexassTA ]</p>
How about giving us a full list of all of your engine mod's? Stat and fan settings can wreck havoc with emissions testing. When was the oil last changed in the car? What temp was the car at?
Could leaning the car out with a MAFT, get the hydrocarbon's down enough to pass anyone?
I have a MAFT and I could really lean it out....
my cam is a
222/222 .563/.563 112lsa
other little mods are in sig...
