Holy Crap!!! This Is It!
Old Mar 30, 2007 | 01:56 PM
  #41
SpdFrk1990's Avatar
Originally Posted by CaliboyTA
i know its an old post but just an update on my car with this similar ticking noise. I just finish with my cam install, which i upgraded my whole valvetrain and the ticking noise is gone. so it has to be the valvetrain. I've noticed that i had alot of slack on my timing chain. which could cause this noise.
Thanks alot caliboy I think mine is prob my lifters I might be looking for a cam upgrade soon also.
Old Mar 30, 2007 | 03:20 PM
  #42
Tootall's Avatar
could be a bent push rod, or a loose lifter, or a collapsed spring
Old Mar 30, 2007 | 03:29 PM
  #43
BLKWS.6's Avatar
A lot of LS1's just do it period. My car has not really been beaten on and I think it is normal. My friend's car with only 26K miles on it does the EXACT same thing. I bet you just can't hear yours over the exhaust
It would have to be all 16 pushrods/springs. Noise is uniform and minute. Just a pushrod engine. Dad listened to it and agree's. My 5.0 does it too and it has done it since day 1 and 0 miles. LS1's are just all-aluminum and you hear it a lot more.
Old Mar 30, 2007 | 03:40 PM
  #44
BLKWS.6's Avatar
EDIT: Slack in the timing chain would just retard the cam a bit and cause no extra noise.
Old Mar 30, 2007 | 04:02 PM
  #45
01pewterbird's Avatar
Are you guys talking about the fast rattling sound it makes as the revs come down at 15 seconds, then at 30seconds, then again at like 38 seconds? If so, My car does the exact same thing, odd thing is, it is only really pronounced when the oil has <1000 miles on it, after that you can barely hear it. I really hope thats the sound you guys are talking about and calling it normal because this is something that has always bugged me and I could never really explain it to people over the fourms.
Old Mar 30, 2007 | 07:16 PM
  #46
BLKWS.6's Avatar
Lmao, yes, that is it. I have TRIED to tell SpdFrk1990 that it has to do with his recent oil-change. See man? It will clear up, just drive it a tad Mine does the SAME THING.
Old Mar 30, 2007 | 11:05 PM
  #47
92SilverSHO's Avatar
my car does the same thing, Only after i started using GC, but oh well. Its took my oil consumption down whatever i had at the time to nothing and gave me a louder tick, tick. In a year im replacing the lifters anyway so they just have to hold on if they are bad.
Old Mar 30, 2007 | 11:11 PM
  #48
SpdFrk1990's Avatar
Yeh but I still think if I get better lifters it will stop.
Old Mar 30, 2007 | 11:19 PM
  #49
stangkiller2005's Avatar
why does everybody say they will change lifters when they change the cam? will you guys be removing the heads? u have to take the heads off to change lifters... i would save money for a H/C swap
BTW my car does the same noise... did it with stock cam, and samething with bigger cam.. when i get heads, and better lifters ill let ya kno
Old Mar 30, 2007 | 11:20 PM
  #50
SpdFrk1990's Avatar
Yes heads/cam kit.
Old Apr 5, 2007 | 07:31 AM
  #51
Well I sure am glad to hear most ls1's make this sound. My car has done it since the first oil change, which was RP, stopped after some miles, second oil change with RP same thing, then M1 0w40 same thing, then now to GC 0w30, same thing again but with miles it goes away. I just don't understand this, it doesn't make sense to me that as the oil is in there longer it goes away, doesn't oil thin out if anything over time?
Old Apr 5, 2007 | 07:49 AM
  #52
briannutter's Avatar
Piston slap can indeed be a tick and not a gutteral knock. When it's cold it will do it, but if a piston is designed with too much taper-even when warm, it won't ever swell "enough". GM did this because they have to deal with customers driving in extreme temperatures and it's better to make a bit of noise than to seize a piston-which becomes warranty time.
The way you can tell is it won't do it under load, but under light load and transient throttle, it will come and go. It make you want to floor it all the time to get rid of the noise.
*Some* forged pistons are quieter than O.E. cast . It boggles my mind that people complain about 4032 and 2618 forged when the factory pistons are worse than both.
-Brian Nutter
Old Apr 7, 2007 | 10:24 AM
  #53
-Brian Nutter
The rattling sound in the video is definitely not slap.
Old Apr 7, 2007 | 03:50 PM
  #54
SpdFrk1990's Avatar
Im thinkin the lifters and specialy in 01 just sucked cause I hear a lot of guys with 01's have this prob.
Old Apr 7, 2007 | 04:24 PM
  #55
I've wondered myself if it is 01 specific.
Old Apr 12, 2007 | 03:00 PM
  #56
ONEBADASSWS6's Avatar
I don't think so.
My 98 does the exact same thing
Old Apr 12, 2007 | 03:07 PM
  #57
SpdFrk1990's Avatar
I wouldnt say 01 specific but I would say ive seen more 01's with the problem so it's 01 prone lol.
Old Apr 12, 2007 | 04:08 PM
  #58
CASHss99's Avatar
mine does it to i use mobile1 10w30 whats better
Old Apr 12, 2007 | 04:12 PM
  #59
BLKWS.6's Avatar
30w M1 sucks. 0-30 German Castrol or 0-40 M1 is better.
Old Apr 12, 2007 | 04:25 PM
  #60
CASHss99's Avatar
are those thicker, the m1 is to thin right,, how much does those run for? and what bout royal purple
