View Poll Results: Would you degree the cam in my situation?
YES
47
71.21%
NO
19
28.79%
Voters: 66. You may not vote on this poll
Degreeing A Cam: Yes Or No
Old Nov 19, 2006 | 11:48 PM
2KThunder's Avatar
Thanks for the info, where can I get the engine turning tool is it universal?
Old Nov 20, 2006 | 05:24 AM
Irocss85's Avatar
you can get it from summit, but they might not know the part #. for that you might have to call comp cams directly. call there tech support line. it is LS1 specific. not universal.
Old Nov 20, 2006 | 04:34 PM
Slowhawk's Avatar
LS1Tech Sponsor
Degreeing a Cam is the right thing to do but probly 95% of the people don't.Thats why Thunder/TSP ect have the Cams ground for dot-dot install. I've checked many Cams that we special order and the worse was off 2 degree's which made no power difference.
Old Nov 22, 2006 | 10:36 PM
NSTY WS6's Avatar
If it doesnt make a power difference, why would you want advance?
Old Nov 22, 2006 | 11:51 PM
Irocss85's Avatar
mostly cause it will shift the power curve in the rpm band lower. as in same peak HP, but now maybe 200rpm lower peak point. in theory.
Old Nov 28, 2006 | 08:38 PM
Pewterme's Avatar
I say yes also. After my cam install my torque sucked. Went from 350 to 356. This was supposed to be a torquey cam so I knew something was wrong. Got it degreed and retuned and tq went to 382.
