The B&B Tri-flow was just delivered
Man, this thing comes in two pretty big (one heavy) boxes. However, upon opening the packages I was greeted with a thing of pre beauty!!!! This thing looks absolutely awsome (quad tips). I see the "minor" restriction in the tip, but it doesnt look like it would impede performance much, if at all.
All I can say is WOW...good job B&B. Now to get them installed.
Re: The B&B Tri-flow was just delivered
Install is just basic. Problem is sometimes one side will hand lower than the other. All you have to do for this problem is bend the bracket where the exhaust comes up and over the rear end right before the muffler. Bend it till it sits up higher or lower whichever way it has to be adjusted.
Casey
Casey
