Upgrading combo... Look at my cam specs.
upgrading my combo and need some cam advice..
382 stoker
3.905x4.0
-8.6 pistons
6.125 rods
.042 gasket..4.0 bore
TEA stage 2 5.3l heads..59cc
come up with 11.5 compression.
ls6 intake
ported tb
85mm maf
lid
pacesetter lts
6 speed
car currently has a comp 240/248 609/615 112+4. Should I change my cam or run the one ive got? It has a 48* closing point which results in 9.4:1 dynamic compression.
car is a driver, pump gas and has a 200 shot as well. I want this thing to pull to 6600-7000
Please advise in my cam selection
Mike
382 stoker
3.905x4.0
-8.6 pistons
6.125 rods
ls6 intake
ported tb
85mm maf
lid
pacesetter lts
6 speed
Mike
From my calcs you are ~ 11.64 SCR and ~ 8.73 DCR (unless your -8.46 are domed pistons?) and I used a out of hole piston deck height of .010 out.
60* EVO will push that trq way high, don't expect too much below 5K/rpm
20* overlap.
Seems like a good choice being slightly exhaust biased from TDC EVC=8 while IVO=12
Should pull to 7K with no issues.
20* overlap.
how are you getting those calculations??? im using a dynamic compression calculator on line and it says 11.5 9.37
my specs are
3.905 bore
-8.6 pistons
4 stroke
6.125 rod
59cc head
4.0 gasket bore
.042 compressed thickness
48* intake closing.
.007 out of hole
WHAT WOULD BE THE BEST CAM FOR THIS COMBO??? Want a really mean street cam that will pull high into the RPM's.
this is in a 6 speed car. like the thump and drivability needed is about a 5 on a scale of 1-10
bout to start assembly and want to make the best decision. filled out comps custom cam sheet twice and havent heard back from them at all.
Thanks,
Mike
my specs are
3.905 bore
-8.6 pistons
4 stroke
6.125 rod
59cc head
4.0 gasket bore
48* intake closing.
.007 out of hole
Thanks,
Mike
