Need a little help...
Old Dec 5, 2001 | 11:53 PM
Sporadic's Avatar
Default Need a little help...
My car hasn't been running the greatest lately. I pulled the codes and my O2 sensors have crapped out. I replaced them with some used ones I had, but I'm still getting a error on B2. Which side of the car is each bank, B1, B2, driverside, passenger? B2 always shows a little low at WOT and idle, I'm thinking an exhaust leak although I can't hear it. Also, at various times I'm getting really weird 02 readings, like .006 to .200 for brief moments? Should they ever read this low like when I let off or at part throttle?
What should my 02s read at Idle?
I also noticed my Fuel trims are at 0, which I though was weird with all my mods, heads/cam. I'm using the old DOS Autotap version, so I might upgrade and see if this clears up this problem?
Matt
[ December 05, 2001: Message edited by: Sporadic ]</p>
Old Dec 6, 2001 | 10:47 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Need a little help...
O2 readings at idle will fluctuate rapidly from like .0 to .9 that's normal.
B1=front o2s
B2=rear o2s
S1=driver's side
S2=passenger side
O2s may have crapped out if they get contaminated you running rich?
Old Dec 6, 2001 | 11:08 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
B1 = Bank 1 (driver side)
B2 = Bank 2 (passenger side)
S1 = Sensor 1
S2 = Sensor 2
So the sensors to monitor are B1S1 & B2S1 for pre-cat.
Old Dec 6, 2001 | 01:46 PM
Jax White TA's Avatar
[quote]Originally posted by gwj:
<strong>B1 = Bank 1 (driver side)
S1 = Sensor 1
S2 = Sensor 2
So the sensors to monitor are B1S1 & B2S1 for pre-cat.</strong><hr></blockquote>
Yep, thats the way I understood it too.
Old Dec 10, 2001 | 11:28 PM
Sporadic's Avatar
Just a little update guys, I put some new 02 sensors in. Looks like it cleared up the problems. I haven't had any codes appear all night. The car's running much better! I also fixed the little exhaust banging problem. <img src="images/icons/grin.gif" border="0">
And I also verified by pulling the sensor, B1 = driver side, B2 = passenger side.
Thanks guys.
Matt
Old Dec 11, 2001 | 10:35 AM
2quick4u's Avatar
Matt,
Have you been running leaded race gas at the track? If so, that is what took out your sensors.
Old Dec 11, 2001 | 10:35 PM
Sporadic's Avatar
I haven't had race gas near my car. It's been running rich though, I think that might be the culprit.
Matt
Old Dec 13, 2001 | 10:06 PM
Sporadic's Avatar
Well guys, the night after I replace the 02s my SES light came back on. <img src="gr_images/icons/mad.gif" border="0"> I just pulled the codes,
P0135 & P0155 - 02 Sensor Heater Circuit Malfunction (Fronts)
P0140 & P0160 - 02 Sensor Circuit No Activity Detected (Rear 02 sims)
Ok, what in the he!! is going on. Could I possibly have a short somewhere causing this crap. Anyone know the voltages of each wire in the harness so I can test?
Any ideas?
Matt
[ December 13, 2001: Message edited by: Sporadic ]</p>
