Could clogged cats cause this?
Here are my mods:
ARE 360 with S1 blower ported heads and 221/221 114LSA 558 lift cam
Yank 4L70 tranny
12 bolt with spool 4.11s
dual 3inch carsound cats in MAC Ypipe with a 3inch extension and bullet muffler under the axle.
Dynoed today and my horsepower curve with the converter locked is almost straight across from 5000rpm and up. (spiked at 365RWHP and 404RWTQ)
I lost 2mph when I put the cats on the car (118mph to 116mph) (Best ET 11.70116.5mph with a half throttle 1.67 sixty in first with cats on the car)
I am wondering if they could be clogged up or would I have another issue. The cam should be peaking around 6400rpm.
Any ideas?
Thanks,
Chris
ps- My converter was flashing to 4800rpm on the dyno!! <img src="images/icons/shocked.gif" border="0">
[ December 07, 2001: Message edited by: Chris ARE 360 ]</p>
hope this helps some danny
Should run a lot better when it is all straightened out <img src="images/icons/grin.gif" border="0">
Chris
Have you a-taped on the dyno? Maybe you’re getting real lean above 5 grand?
Things are solid fuel and timing wise.
I am going to switch to the offroad and dyno again next week if there is no snow. That will tell me if the cats are the problem.
Cheers,
Chris
If used, maybe someone messed them up with heavy back-fire, race gas, poorly running engine, monster cam, etc.
If new, <img src="images/icons/confused.gif" border="0">
