AFR's RESOLUTION (Valve tip issue)
We all work hard to pay for the parts to feed our speed addiction, it certainly gives you a good feeling to know you've not only got the best parts, but the best customer service to stand behind it...
thanks
Wesley
I've already touched on this topic but since it's worth repeating, whether you have a problem now or TEN years from now, AFR will stand behind it. We wouldn't go thru all this trouble and drop the ball on guys that the issue takes a little longer to manifest itself....we assumed that to be the case. Our guess is most of the bad valve issues will clean themselves up in the next 12 months depending on how many miles and how hard the car is driven. Assuming the percentage stays where it is now (very low), there will only be a few isolated cases after that (guys that put VERY little time on their cars).
Either way....we will address it no differently then the way we are handling it currently.
Thanks,
Tony
Maybe this should be a sticky for awhile so all can see.
Thanks,
Tony
AFR's customer support comes as no surprise. It's the same I received when purchasing and installing your heads. I do have a question. Would the wear on the valves look the same if using the Crane adjustable roller tip rockers? I've had the rockers off many, many times and didn't notice anything (but wasn't really looking for specifics). My valvetrain is noisy and I have almost 5000 miles on the heads.
Thanks,
Byter
