upgraded valvesprings on stock motor????
just wondering if there is any advantage to upgrading my valvesprings even with stock rockers, pushrods, and stock cam? ability to spin the motor higher? mine stock liked to be shifted at about 6400. got the best times that way, but from what i read it's not good for the valvetrain that high. any thoughts?
Chris
Chris
Chris
Chris
Moderator
Received 1,838 Likes
Because when a beehive spring breaks the valve drops which doesn't happen with dual spring. 95% of the time the inner spring will keep the valve from dropping into the cylinder and alert you to the problem... And you're right, this thread is 14 years old.
Yeah because those millions of GM engines that came factory with beehives are dropping like crazy............hardly a day goes by when I don't see 2-3 dead on the side of the road during my 7 mile commute to work.
For a .620 lift cam the duals argument is reasonable, for a stock cam, it isn't.
