What are the specs on a....
Old Dec 10, 2001 | 02:49 AM
haole_boySS's Avatar
Default What are the specs on a....
B1 and T1 cam. I was thinking about going hot cam and someone suggested looking at the B1 and T1.
I know the hot cam is 218/227 525/525 114? Do you want the intake #'s to be the same or different as on the hot cam?
And if by chance someone didn't mind explaining to me what I am looking at as far as the differences in the 3 cams?
thanks in advance
Andy
[ December 10, 2001: Message edited by: haole_boySS ]</p>
Old Dec 10, 2001 | 02:53 AM
QUASAR's Avatar
Default Re: What are the specs on a....
T1 & B1 have the same lift and duration
221/221 558/558
the T1 is on a 112lsa and the B1 is on a 114lsa. They are essentialy the same cam exept the B1 makes power a little higher in the RPMs. The T1 idles a little rougher. I will let someone else explain the rest as i am learning myself. <img src="images/icons/wink.gif" border="0">
Old Dec 10, 2001 | 06:39 AM
Nickn20's Avatar
hotcam is also a 112 LSA, for a M6, I think the T1 is good choice, it makes TQ sooner than the B1, either one is till a good choice.
Old Dec 10, 2001 | 11:48 PM
TTT
Old Dec 11, 2001 | 12:11 AM
ExtremeZ28's Avatar
pick one of the other they are both good cams <img src="images/icons/smile.gif" border="0"> im most likely going to go with one of the two or maybe even a hammer cam....
Old Dec 11, 2001 | 08:16 AM
Jax White TA's Avatar
Get the Hammer (C1). Its a 222/222 566/566 112 LSA cam. Single pattern cams are great for the everyday engine. You want to start enlarging you exhaust lift and duration if you throw on a power adder. The stock cam is not a single pattern however so they are just fine for NA use if you find one you like. I made 473 RWHP and 557 RWTQ on my Hammer cam, SLP LT's, and a 100 shot with no custom tuning yet. Oh, and dont get a cam with a 112 LSA if you have a auto and dont plan on custom PCM programming right away. Raughhammer has a nice databse here of cams and info with each one: http://xs-fx.com/raughammer/cam_info.htm
Old Dec 11, 2001 | 09:03 AM
TA_2001's Avatar
Here is another place where setups are listed
with cam info..
See the data http://ls1info.com/camstats/showdata.php
Enter your data
Old Dec 11, 2001 | 09:08 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Do you guys know that MTI is currently having a sale on these cams in the Sponsor section?
Take a look!
Tony
