Cam Package Need Help
Old Nov 23, 2006 | 11:22 PM
rgk615214's Avatar
Default Cam Package Need Help
So Im wondering do i need the 600 or 800 dollar cam package from thunder racing. I am def getting a tr cam so do i need the dual valve or single valve spring package?
Link: http://www.thunderracing.com/catalog...&vid=3&pcid=51
Ne help much appreciated
Old Nov 24, 2006 | 03:06 PM
tamikews6's Avatar
$539 and $719 now
Old Nov 25, 2006 | 09:19 AM
rgk615214's Avatar
So which one do I need to get???
NEONE?
Old Nov 25, 2006 | 09:53 AM
tmoneyr007's Avatar
By TR Cam are you referring to the CheaTR, TRak, or TRex?
Old Nov 25, 2006 | 10:11 AM
mullenh's Avatar
that depends on which cam you select. which cam are you looking at?
Old Nov 25, 2006 | 10:48 AM
rgk615214's Avatar
im looking at a tr230 or less, i want a cam that wont risk killing my trans. Also, what size could i get that i wouldnt have to use a torque converter with it, like what is the size limit where it would still be drivable without a new stall
Old Nov 25, 2006 | 12:02 PM
rgk615214's Avatar
Noone knows
Old Nov 25, 2006 | 04:45 PM
rgk615214's Avatar
will i need a stall with ne cam???
Old Nov 25, 2006 | 05:09 PM
mullenh's Avatar
well that is easy then if it is the 230\224 you are border line but the cheaper package is fine. anything more and you should upgrade
Old Nov 26, 2006 | 07:27 PM
rgk615214's Avatar
Are there any cams you can use without installing a new torque converter?
