cam install last night, ran into coolant problem.... help!
OK, so we were getting the radiator out, and the small tube that goes from the throttle body to the radiator right under the fill hole snapped off the radiator, you know, the one for the coolant to run through the TB.
so now i'm stuck with the tube coming out of the throttle body and the plastic peice from the radiator stuck inside the tube, leaving a tiny tiny hole in the plastic of the radiator, the idea right now is to epoxy that tiny hole shut, so it doesn't leak, bypass the throttle body, and run a tube to the OTHER tube that comes from the overflow tank, and just use a tee and tap into that tube....
the only issue is, will the coolant rushing from the TB to the radiator go down into the overflow, or suck up into the radiator? thats the only thing holding us back from just tapping into that line.
excuse me if im' not making any sense, its 10am here, and i've been up since 7am yesterday, so bear with me
any advice is appreciated.
oh we tried epoxy'ing the original peice that broke off back in its place, but it just wont stay there.
JK, we did follow 2xls1's advice, and it worked great, its actually curing right now, but it went smoothly and looks good.
thanks for the help
