Car went boom....
To the original poster, what brand were the heads and do you know what brand valves were used? It looks like the head of the exhaust valve broke off. You can still see the stem in the guide. Is the intake stem still in the guide too? It's hard to tell in the picture.
no, thats wrong, ive personaly seen a cam that was installed many degrees wrong (several teeth) it did the EXACT same thing.
lets think about this people: he said all the valve springs were intact. this means that he didnt break a valve spring, and the valve didnt drop. what does this mean? this means that valve head fell off the valve stem or the valve ran into the piston causing it to break. i dont know about you guys but ive never ever heard of a valve just falling appart in a motor.
the only thing that could have happend was that the piston ran into the valve. since he said it was under normal driving (and if this is true it means that it wasnt in high rpms and it wasnt a mechanical over rev). so the valve ran into the piston, breaking the valve off. the only way it could have happend is if the cam was installed correct.
to the poster, take off the front cover and take pics of the timing chain, if its not lined up dot to dot you have the solution to your problem. most LS1 cams have the advance ground in, so you dont need to degree them or anything.
i dont think there would be a case where you would see the same exact thing happen in all 8 cyls.
Once i saw the spring sticking up after they remove the valve covers... I was Sick!! You could almost pull what was left of the valve right through the top of the head!!
Once again... When i p/u my car it had an idle problem...(surging in both park/drive) 700-1000 up... down... Initially i though it would "re-learn" idle.. However, that was NOT the case... When the car "died" there WAS NO KNOCKING.. i was running about 60-65mph... and it simply died... I pulled over, popped the hood, and there was a coolant "vapor" coming from the air lid...??? i "assumed" that it maybe had an intake leak and possibly crapped out my MAF...
After 4 hours of waiting on a flat bed wrecker.. i finally got the car to the shop.. The mechanic came out... attempted to start my car and it was @ that point that it started knocking.. NOT banging... simply knocking.. the owners were @ lunch.. I was SO pissed ( motor was just built) & had not had anything to eat, so i walked to get a bite and VENT to myself... It was upon my return that one of the owners said.. "It's locked up"... I'm like WTF????
The heads are LS6's(243) out of my brothers Z06... they had "maybe" 3Kmi on them.. I had a local guy,,"hand port" the heads & upgrade to the Patriot Dual Golds.. & yes the valves were stock... I DO NOT race my car.. persay...
For the few days that i had it... i NEVER took it above 3500-4000 rpm... I NEVER heard any kind of detonation... I will say that the day of... when i first cranked it up that morning... it was hesitant when turning over...
Lesson learned.... I will have LG Motorsports build my next motor @ the first of the year... Maybe sell my current cam 232/236 595 601 114 ( comp) & upgrade to the G5 series...
THANK YOU ALL for your thoughts, replies.... I "truly" appreciate them..
