SI7 cam question...
Old Nov 27, 2006 | 09:13 PM
GreenBlood's Avatar
Default SI7 cam question...
I am getting and LS1 in the summer and most likely trying to get a cam as next year's christmas present...I was thinking something along the lines of the torquer v3 or SI7 from speed inc...None of the threads i searched on the SI7 gave me any valuable info, so I was wondering if anybody knew about it? I am sure by next christmas TSP or SI will have newer cams, but for now I am lookin at these two...Anybody have any input besides the fact that the Torquer v3 is proven...Also, this will be a cam only setup...thanks
Old Nov 27, 2006 | 09:43 PM
waterbug1999's Avatar
Well, I would get most of the supporting mods first.
Old Nov 27, 2006 | 09:53 PM
GreenBlood's Avatar
of course, that'll be this summer and up until christmas...i plan to have full boltons and a stall matched to the size of the cam...of course the valvetrain will be updated with the necessities as well...
Old Nov 27, 2006 | 10:07 PM
The V3 cam (231/234 .643"/.598" 111 LSA) VS (SI7 238 244 .605 .612 110) cam...
**** it, go big or go home... But hell, just read your post again and you are talking about X-mas in 2007? So, post up then.
Old Nov 27, 2006 | 10:10 PM
GreenBlood's Avatar
yea, i am new to the LS1 game...LT1 and vortec 5.7 previously, but i was just curious in case i strike some luck money wise this summer....I don't know much about cams...I read all the stickies, but not sure which numbers for the cams are better, I understand LSA but not sure how the lift and durations affects it, any help would be appreciated..Someone mentioned a cam only SI7 layin down 425, is that true, I can't find the thread again...
Old Nov 27, 2006 | 10:21 PM
Well, cam only is with all supporting mods I am sure. The SI7 cam seems pretty big for a 347CI, I mean, my quick search cam up with guys using it on a LS2 and a 383. It can be done but is going to take ALOT of tuning.. Its not all about the cam but all about all the supporting mods together.. I would pick the V3 and build off that.
There are guys on here runnin 22X cams and miled AFR's hittin 450+.
Old Nov 28, 2006 | 11:48 AM
GreenBlood's Avatar
well of course it has the mods, but thanks for the otehr info, anyone else have input? Would it be better if I stepped down to the SI6 vs the Torquer v3?
Old Nov 28, 2006 | 11:53 AM
98_Formula's Avatar
there are many other cams that have specs similiar to that, which appear to do well in the stock ls1 motor (plus required bolt-ons and stall) like the ms3, ms4, trex, lg cams etc... are you set between these two or are they just 2 cams you happen to come across...
i haven't had experience with any of the cams so i can't offer much help other than my own research when decdiing if i wanted to go cam only or not, but a quick search will show alot of results and i'm sure many threads of people with "cam polls"
Old Nov 28, 2006 | 02:27 PM
GreenBlood's Avatar
i have searched threads for cams and stuff but have jst not found any info on something like the SI7, I have seen other cams, and i have other choices, but I dropped the idea of an MS3 because I heard its better up top, and I want a torquier cam for the street...I like the MS4, but I think it would be more beneficial in a heads/cam package, and I don't feel safe running that high of a lift...Also, I have seen that the Trex is more of a drag cam whereas as i stated before, I want a nice torquey street cam...I was also looking at something like the G5x3...thanks for the input so far...
Old Nov 28, 2006 | 06:40 PM
Well, ALL cams would be beneficial when adding better heads... MS3, MS4, SI7, G5X3, G5X4 are all cams that hit peak power at 6500+ rpm...
I have the X3 and love the cam so far.. I have it shifting at 6600 now. I could go hire but do not want blow out my rod bolts.
Old Nov 28, 2006 | 07:59 PM
cws T/A's Avatar
I figure with a set of TrickFlow 215cc heads the rwhp should be north of 450 .
Private Message: Re: S17
Today, 10:01 AM
Jon @ Speed Inc
LS1TECH Sponsor
Trader Rating: (0) Re: S17
Quote:
Originally Posted by cws T/A
Do you have any results for this camshaft , I cant find one person running it searching the internet.
I am considering buying this cam ,any help ?
I am stock internal 00 ls1 / mods as of now
Lid
LS6 Intake
1 3/4 Longtubes
3'' Xpipe/ dynomax bullets/ turndowns
built 6speed
ram flywheel / ram HD clutch
9inch /s60 soon 4.10s 26'' or 4.30s and 28'' cant decide
Curtis
The highest # ever was 509 I believe with ET heads and 1 7/8ths headers on a GTO.
With your combo I would expect 390 give or take before doing the heads. It could even be a few less.
Jon @ Speed Inc
View Public Profile
Send a private message to Jon @ Speed Inc
Send email to Jon @ Speed Inc
Visit Jon @ Speed Inc's homepage!
Find More Posts by Jon @ Speed Inc
Add Jon @ Speed Inc to Your Buddy List
Delete this Message
