i want fans on with key?
I would like my low speed fans to come on all the time with key. I had done this on my 93 f-bod by grounding one connection of the relay, the relay on the 99 is different...the green wire is ground but if i jump it to ground the fans come on even without key on. anyone know which connection to ground? anyreason not to have fan on all the time? thanks.
Re: i want fans on with key?
i really dont want a switch...i just want them on all the time. If i put a switch on the green wire from the relay that would work. but i dont want another switch.
Location: Live Oak, FL - in the woods where the creatures lurk.
The only thing I can think of is if you can use a wire that is hot when the switch is on to energize a (separate) relay and put the relay signal wire to ground, which will energize the fans. BTW, you can access the pcm to fan relay signal wires from the wiring of the larger connector on the passenger wheelwell.
