Ok, so is everybody agreed on the fact that the stock, gutted MAF is the best for
LS1 Tech Administrator
Re: Ok, so is everybody agreed on the fact that the stock, gutted MAF is the best for
Huh? Explain what you mean.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
[quote]Originally posted by Patrick G:
<strong>Huh? Explain what you mean.</strong><hr></blockquote>
I saw your post.
From what I extrapolated from your experiment, a bigger MAF is not necessarily better ; unless you have a stroker motor or possibly a H/C package.
I saw your post.
SSU Moderator
i will concede that a properly tuned MAF is best in any situation. hogging one out and throwing it on is not good. even leaned out my 98.
Ryan
Ryan
What the post said was: From an airflow standpoint, there is no benefit to going to a ported stock MAF or 85mm MAF, even with a heads/cam motor like mine.
HOWEVER: I did pick up ET on my '98 Camaro and '00 WS6 by running ported stock MAFs. The reason I picked up ET, was not because of increased airflow, but because the motor liked the extra 3-4 degrees of timing. This was proved on the dyno and at the track. I went faster with ported MAFs...but again, it was because the motor liked the tune-up better, not because of the added-airflow.
__________________
Coal Mining Director
IMHO a cheap way to get additional timing (if your engine needs it) is a ported stock maf. I like the 85mm screened maf for my car...part throttle A/F ratio's are dead on and the larger diameter flows well with the screen (also LPE picked up approx 5 ENGINE hp on their ASA engine with the 85mm screen maf vs the 75 mm screened maf...which would be 3 0r 4 rwhp). A no screen 75mm is probably close to a screened 85mm in flow.
From John Juriga GM Powertrain Cheif, commenting on the larger Truck MAF used in the 385 HP 2001 LS6:
"The other changes for the LS6 are the higher-capacity mass air flow (MAF) sensor from the 6.0-liter, Gen III truck engine. It’s worth 2-3hp and its integral intake air temperature (IAT) sensor simplifies the engine controls and reduces cost."
Interview with John Juriga - Gm Powertrain Engineer
