TR224 questions
Old Nov 28, 2006 | 09:35 PM
PREDATOR-Z's Avatar
Originally Posted by zspot98
Get rid of that 2300 stall and step up to a 3600-4000 and the 224 cam will be mean from a roll too.
Hopefully you won't be spending too much time under 5200 RPM's. Also, PREDATOR-Z would you say that the 224 cam in a car w/ a 3600 would pound on a car w/ a 224 and a 2300 in it?
Assuming they are equal otherwise and they can hook, yeah the higher stalled one should beat it by at least 2/10th in the 1/4
Old Nov 29, 2006 | 05:32 PM
jcolews6's Avatar
My TCI 2800 stall on my LT1 took .2 off my 60ft times.
Old Nov 29, 2006 | 06:48 PM
FireSilverLullaby's Avatar
How slow is it when you have a 224 with a stock stall. Im in the same postition as you but i want my 10bolt to hold together cause i dont have 2k for a 12bolt, or do you think like a 3200 stall/cam and 10bolt in an a4 would be fine.
Old Nov 29, 2006 | 06:54 PM
TXZ28LS1's Avatar
im for sure going with a 3200 vigilante stall and some gears. i dont ever take my car to the track, so i dont really worry bout my rear end.
Old Nov 29, 2006 | 07:09 PM
john563's Avatar
I have a 34-3800 stall and TR224/112 cam and the 10 bolt is still in and no problems.I have a friend(gillbot)has a TR230/224/111 cam a4 399rwhp and on the 10 bolt as well.A4 are more forgiving than 6speeds
Old Nov 30, 2006 | 12:09 AM
PREDATOR-Z's Avatar
I'm, running the numbers in my sig + 150>200 shot dry on my 10 bolt (it is slightly modified: Moser axels, Micronite treated gears, TA girdle and frequent lube changes), so far so good and not a peep from the rear.
Launching on juice with ET Streets.
