ported TB gains?
Old Dec 19, 2001 | 12:39 AM
bigSS's Avatar
Default ported TB gains?
How much rwhp would a ported TB add for a "bolt-on" car? How much if you add a cam and the likes? I seem to recall LPE sells one for $80-90 bucks. Seems like a pretty good price!
Old Dec 19, 2001 | 01:40 AM
Toxic Texan's Avatar
Default Re: ported TB gains?
Don't know about the gains, but MTI has one for $99 with a core exchange. I plan on doing it myself. <img src="gr_grin.gif" border="0">
Old Dec 19, 2001 | 11:38 AM
J'sRamAir's Avatar
I'll take a stab...5-8rwhp for bolt-on car and maybe 15rwhp for heads/cam car.
Old Dec 19, 2001 | 11:45 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Many bolt-on people gain nothing from one. I think 15RWHP on a heads/cam car is a very high estimate. Maybe on a bigger cubed motor, but probably closer to 7-10 on a heads/cam car depending on the intake (LS6 or not) and the size of the valves and cam.
Old Dec 19, 2001 | 08:49 PM
Jason99T/A's Avatar
I can shift faster than you.
Heads/cam cars are seeing ~5-7rwhp w/ a ported TB.
A stock heads/cam only car gained 4rwhp locally.
We'll be testing one on my bolt-on car soon.
Old Dec 19, 2001 | 10:28 PM
Ebbsnflows's Avatar
If I got 5 hp for $99...I'd be satisfied. $20 per HP isn't a bad ratio (after you've done the easy cheap stuff of course)
Old Dec 20, 2001 | 01:08 PM
RPM WS6's Avatar
Porting the TB won’t change the dead spot that 3.23 A4s have between 30mph and 45 or so. The only thing that can help this is a nice big TC <img src="gr_grin.gif" border="0"> That dead spot is because your car won’t downshift to first and you’re stuck in the basement of second where there’s no power. A high stall TC will skip you right past that low power low rpm range and make a big difference here. But even then, it’s still not like throwing it back to first manually at 35mph <img src="gr_eek2.gif" border="0">
[ December 20, 2001: Message edited by: RPM WS6 ]</p>
Old Dec 20, 2001 | 02:00 PM
Wicked Ls1's Avatar
What I think it is is that I didn't screw in the throttle body screw in properly. My car idles higher since I have put it back on. I am 95 percent sure that the actual porting of the T/B ISN'T why I feel a different area of power. I think it is because I put something back on incorrectly and unsettingly. So in a way the Throttle Body porting did help me out with power. I didn't say it was that actual porting that did it. <img src="gr_grin.gif" border="0">
I doubt you get more than 3-5 horsepower from a heads/cam car, much less stock. <img src="gr_sad.gif" border="0">
-Jason
[ December 20, 2001: Message edited by: Wicked Ls1 ]</p>
Old Dec 20, 2001 | 11:10 PM
J'sRamAir's Avatar
One sure fire way to get responses to a thread is for someone to answer a question wrong or not quite right. LOL.
Old Dec 21, 2001 | 12:13 AM
neophytal's Avatar
wish i could tell ya... my mods are in sig, hopefully ill get a dyno session in soon and see at least what the car is pulling..
Old Dec 21, 2001 | 12:27 AM
bigSS's Avatar
Lol, isn't that the truth? <img src="gr_stretch.gif" border="0"> I figure maybe 5rwhp on a mostly stock car.
Old Dec 21, 2001 | 12:42 AM
Wicked Ls1's Avatar
I'm not sure about definite dyno numbers but... I ported mine out on Sunday. Having an A4 I have no jump or pull around 30mph. Now I can stabe it anywhere from 1 to 45 and it pulls like a BEYOTCH! <img src="gr_grin.gif" border="0"> My only problem is it pulls alot harder from 0mph to 70. But when my car should shift to 3rd I hit the rev limiter. I "felt" a gain in power but now I need an HPP3 to raise my shift points and it will be all good. I did not lose any high end horsepower either, it just feels like I gained a crapload of low end <img src="gr_images/icons/cool.gif" border="0">
-Jason
Old Dec 21, 2001 | 12:56 AM
Terry Burger's Avatar
OK I call BS, no one can "feel" 3-4rwhp like you describe.
