Best nitrous cam ?
Old Nov 28, 2006 | 10:02 PM
whywhine's Avatar
Default Best nitrous cam ?
Going to be running 5.3 heads stock cubic inch motor ls6 intake,150 dry and later on more nos and the regular bolt ons,just want the best bang for the buck. Thanks for any help
Old Nov 29, 2006 | 01:43 AM
forgedbluess's Avatar
If i was you i would have a custom cam built and there not that much more expensive then any other cams. I tried the ms3 and that cam liked a 200 shot, i went with a 239/242 .595 .595 111 lsa cam and did a 250 shot fine with that cam as well but im getting a custom cam built for my 370 to handle up to a 400 shot dual stage. I was qouted $240 for a custom grind nitrous cam and thats not to bad.
Old Nov 29, 2006 | 04:44 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Most cams on a traditional split grind will handle retarded nitrous. Both of my cars have nitrous grinds....only one sprays... and sprays hard. 400-500 pills.
Old Nov 29, 2006 | 07:28 AM
PREDATOR-Z's Avatar
Nice pic Orange but your bottles are empty, you you
Old Nov 29, 2006 | 08:55 AM
TeEnAgE pHeNoM's Avatar
I would call comp up and get a custom grind cam......I have comp cam and I picked up 1.6 seconds and 20 MPH on a 150 shot in the 1/4 mile!
Old Nov 29, 2006 | 12:23 PM
Cop Car's Avatar
unless you are spraying more than a 300 shot you dont need a nitrous specific cam
Old Nov 29, 2006 | 02:41 PM
rickyracer25's Avatar
Listen To orangeapeel He's the man when it comes to this spray ****, remember for all the lazy/noobie/learner(me included) modders out there...
"To be successful you don't have to rewrite the book, just emulate the one's that are already successful"
Old Nov 29, 2006 | 03:09 PM
whywhine's Avatar
Ive been hearing alot of good things about the ms3 cam any other good ones?
Old Nov 29, 2006 | 05:29 PM
JPH's Avatar
JPH
224/228 On A 114lsa. You Tell Them How Advance, And Lobe Lift You Want.
Old Nov 29, 2006 | 05:56 PM
Asmodeus's Avatar
I'd go with a 232/246 on a 112.
Old Nov 29, 2006 | 08:45 PM
whywhine's Avatar
why a 232/246 on a 112 and who makes it?
Old Nov 29, 2006 | 09:00 PM
TwistedSS's Avatar
I've got one of those sitting on the shelf behind me....thinking of installing it one of these days
Reverse split cam....from TSP, I hear they work great on gas.
Old Nov 29, 2006 | 09:11 PM
Asmodeus's Avatar
a reverse split isn't really made for big nos shots. you want a balance of intake and exhaust flow. with a reverse split, you're compensating for an inferior intake tract, like, restricted stock heads with big long tubes and straight dumped exhaust. with a big shot, you're injecting the air into the cylinder, so you need to compensate for the increased exhaust volume and need to run more duration. I wouldn't run less than an 8 degree split for a nitrous cam as a general rule of thumb. the cam I listed would be a custom grind, any vendor can order it. and don't be afraid to go big. a 224 is a baby cam and you're looking to make big power, not a great daily driver.
Old Nov 30, 2006 | 06:59 AM
whywhine's Avatar
Yeah i hardly drive it but on the weekends thats what i need...big!!
Old Dec 1, 2006 | 12:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yes they are. Good eye Mark.
I have since moved them over the gas tank into the back glass and then put the back seat in again.
