Problems with rings on 2001s?!
Old Dec 23, 2001 | 08:21 AM
Country Boy's Avatar
Senior Member
Default Problems with rings on 2001s?!
I know someone that took their 01 vette to a dealer for excessive oil consumption and smoking and the dealer told them thats they are told to fix the rings and piston on the 2001 <img src="images/icons/confused.gif" border="0"> Anyone got info on this. My 01 is starting to smoke when I rev it up and I was curious about this. I only have 12k miles on it.
Thanks for the help. <img src="graemlins/gr_xmas.gif" border="0" alt="[santa]" />
Old Dec 23, 2001 | 08:49 AM
WayneSS01's Avatar
Default Re: Problems with rings on 2001s?!
See the Engine Section. 01-06-01-011 Information on Engine Oil Consumption Guidelines
01-06-01-023 Higher Than Expected Oil Consumption (Replace Rings)
http://www.geocities.com/crackeregg/...bulletins.html
Old Dec 23, 2001 | 11:21 AM
Skelton's Avatar
Also check your pcv system for oil contamination. If you have alot of oil in the pcv, that will cause alot of consumption and smoking.
