Beehive springs, good, bad?
Old Nov 29, 2006 | 12:11 PM
jub jub's Avatar
Default Beehive springs, good, bad?
I'm getting ready to replace the springs that came with the AFR 205 heads and I like the looks of the beehive. They seem to be just what the doctor ordered in helping keep valve train weight to a minimum, thus reducing valve bounce, harmonics, etc.
Is there a general consensus out there as to whether or not these springs are any good?
Old Nov 29, 2006 | 12:55 PM
mvvette97's Avatar
there is nothing wrong with them because your factory springs are beehive. I had some 918s break on my ta so that could of been a bad deal. I now use duals. A little more protection
Old Nov 29, 2006 | 01:18 PM
jub jub's Avatar
Thanks.
I understand about the duals offering more protection but I'm pretty easy on my springs and I like to change them often.
I was just curious about things like valve float on a fairly aggressive cam lobe.
Old Nov 30, 2006 | 12:35 AM
Dan_the_C5_Man's Avatar
Dave Vizard published an article delving into this subject in detail; http://www.popularhotrodding.com/tec...retainers.html basically, the behive design is superior in all aspects.
Old Nov 30, 2006 | 01:03 AM
byler900f's Avatar
918's are a great spring for cams under .600 lift.
Old Nov 30, 2006 | 03:41 AM
PREDATOR-Z's Avatar
just get replacements from AFR. call tony mamo, he'll tell you why.
Old Nov 30, 2006 | 05:03 AM
vettenuts's Avatar
One other option is the PSI beehive spring. It is stiffer than the 918 and will set up on the seat with about 135 lbs at 1.750" installed height. I think the k value is 384 lb/in. Titanium retainers are 6.6 grams for these springs.
Old Nov 30, 2006 | 07:13 AM
jub jub's Avatar
Thanks for your opinions guys!
Old Nov 30, 2006 | 01:43 PM
gtovan's Avatar
These are what I am using on my LS7 cam install (650" lift.) PSI 1511ML. ML is for max life, a coating to improve durability. Install height: 120# @1.800" 370# @ 1.150" coil bind 1.100". Katech did comparison testing on a bunch of springs for their LS7 package and this is what they use. You can get them from them or CV Products.
Old Nov 30, 2006 | 05:25 PM
vettenuts's Avatar
Yes, these are the same valve springs that come on the Dart out of the box heads. They are nitrided for longer life.
Old Nov 30, 2006 | 06:13 PM
rickyracer25's Avatar
I like this guy he's smart listen to the man
Old Nov 30, 2006 | 07:17 PM
Katech_Jason's Avatar
LS1TECH Sponsor
That is correct. We use beehive springs on all of our street packages. They have been validated on our Optron valvtrain dynamics test cell and provide the best valve control far beyond the redline.
Old Dec 1, 2006 | 05:01 AM
vettenuts's Avatar
Are you using the PSI springs? If so, what retainers do you use?
Old Dec 2, 2006 | 08:41 AM
vettenuts's Avatar
Question for Katech,
Any idea of the life of the PSI springs?
Old Dec 2, 2006 | 09:38 AM
slt200mph's Avatar
I have 38,000 + miles on a set of PRC platinum duals with a .600 lift cam .. I like the peace of mind that the duals provide and I obviously don't change them often ... they are going to be changed in the next few weeks to a
Comp Cams 921 dual spring for use on a cam with higher lift (.637\.639) ..
Old Dec 2, 2006 | 10:44 AM
jub jub's Avatar
So far, everthing seems to point in the direction of the beehives so it seems these would be the right choice for my small cam.
I wonder what Tony has to say about them? (hint hint)
Old Dec 2, 2006 | 11:12 AM
LS1TECH Sponsor
Katech Ti
Old Dec 2, 2006 | 11:13 AM
LS1TECH Sponsor
Depends on driving conditions
Old Dec 2, 2006 | 12:38 PM
vettenuts's Avatar
Mostly street, occasional drag (I think this is probably the most common driving that most of the guys here do).
