Pulley cause high RPM miss???
Old 02-06-2002, 11:23 PM
gto69judge's Avatar
Default Re: Pulley cause high RPM miss???
Just a note about the sparkplugs:
"DENSO" brand plugs are OEM on a 2002 WS6 we just worked on.
Old 02-07-2002, 01:01 AM
Bad Habit Bird's Avatar
ss slp2 - did you ever get any ATAP logs? was your car actually missfiring or what?
Old 02-07-2002, 07:46 PM
I follow no 1's Avatar
The pully is not supposted to be installed with the impact.Therefor it was probably not removed properly.If you pulled it off with a jaw type and not a bolt type you may have warped it just enough to cause the misfire.I have seen this before.
Old 02-07-2002, 09:13 PM
SS SLP2's Avatar
[quote]Originally posted by Bad Habit Bird:
<strong>ss slp2 - did you ever get any ATAP logs? was your car actually missfiring or what?</strong><hr></blockquote>
I have atap but did not check for miss as such, the problem was at about 4 k was showing 3.9 kr hold same kr as rpm going up,at 6200 showing about 2 kr and tinning drop down to 20 - 22, almost every time at about 52=5300rpm car would miss or hesatate (or do some thing )as stated before talk to several people who were suppose to
know all say some car do this ( hesatation @ 5200) with under drives pulley and some time a little bit even with stock pulley, i do not know if Inad problem with stock pulley or not as i have been running over drive pulley oner 1 1/2 years couple of months ago i changed to a differant under drive pulley and instant NO miss or hesatation at 52-5300 >>NONE< pulls strong all way up to 6250 and Very little KR ( 0.8-0.9 only)
timming stay at 26-27 and the Only thing I did to fix the problem was change the "other " under drive pulley
sorry for so long a reply , just hope this helps some one else fix problem which cost me money and a 1 1/2 year in time
Johnny
Old 02-07-2002, 10:16 PM
MitchR's Avatar
I changed the plugs on my 97 GTP and had missing. It turned out that I either damaged a plug wire or didn't have it back on the plug completely. The dealer was nice and warranty replaced the whole set of wires - it ran perfect then.
Mitch
Quick Reply: Pulley cause high RPM miss???
