how to make ta fog lights stay on w/ hi beam?
Re: how to make ta fog lights stay on w/ hi beam?
I'm sure there is, the fog lights really don't serve much of a purpose anyways...they don't make any light difference when you have the regular lights on....try flipping them on and off at night....you will see no change... <img src="gr_stretch.gif" border="0">
Why are you trying to blind people anyways... <img src="gr_eek2.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
BIGBOS,
Maybe yours are broken. Mine make a difference.
Try to trace wires. If a standard Auto relay is uses find the wire that connects to the high beams and ground it. Maybe!
This is one way we use to do it on the Grand Prix
The factory fog lights are wired to their own relay, except the ground wire is run through the high beam relay. When the brights come on the fogs are no longer grounded so they turn off.
Bend the ground plug on the relay up, connect a wire to it, then attach the other end of the wire to the car body somewhere.
[ February 07, 2002: Message edited by: Paul Bruno ]</p>
