Juggernaut cam? Too big?
I dunno if I spelled that wrong. But I believe LG makes a cam called the G5XX or Juggernaut cam. Is there anyone on this board running this cam on a 347? I have -4 cc valve reliefs. My heads are 62.6cc chambers. I'm going to call LG tomorrow but I am thinking of going with this cam over my current cam. Depends if I also have to buy springs. Anyways any info would help. And if it's too big go ahead and tell me lol. This is going in a mustang that will be driven on the street but I also want the sickest setup I can have for the track using what I have.
Originally Posted by purdueranger
What is wrong with the cam that you have listed in sig? The X4 has just a little less duration than that. How much lift is in your cam right now?
i have 346 motor
i wish i had a forged motor i have stock heads and a 6spd trans am with fast 90/90 with custom x pipe no ac car weights 3360 with stock wheels so i'm still working on dropping weight its a daily driver with the lg xx cam
Originally Posted by bobby1
its a off balanced combo right now but i am adding mods when i get money it makes it easy for some that doesn't have 10k to spend all at once
i am using the 921 comps and as far as i know lg has to install this cam but because of the fact that its not really meant to be street driven it might be better for them to install and tune but i would ask bobby or anthony just to make sure.
Well I can't have them install it. So will they not sell it to me?
Yeah just got off the phone with them and they said they have to install it. And that the G5X4 is actually smaller number wise than what I have. Guess I'll stick with this for now. Maybe go up there down the road and have one put in.
i'm not totally sure because i needed them to install it, i never asked but they are business and they helped me everytime i needed it call them they are very informative and they could give you more info about that. they have never steered me wrong.
sorry about that i thought it might be the case but it is well worth it they are good at what they do
without a pully and on 410 gears in 98 degrees with the car not staying on the rollers made 437.5 to the wheels they have a guy with the same setup on a vette with afr heads making 530 to the wheels. by the way thats with out a pulley and stock water pump.
Yeah I know that. I would love to run that cam but I am in no position to shell out the money for the labor when I can do it myself. I can understand their concerns though.
LG and their secret cams..lame bobby1 have you tried a different dyno to see if the numbers match? I have a friend that spent 8k on a motor at their shop and while the motor does run well they told him it made 440rwhp but once he got back to tulsa and dynoed it he only made 420 after he had it retune to be safe. he aslo had several other problems with their service. Although they attempted to make things right they failed.
