De-Carbonization Procedures
I'm from the Corvette side, but I have a question which might concern all LS1 owners. Does anyone know how to perform the de-carb procedure that the dealers talk about? Or is this something that the dealers won't tell about?
There are other brands out there.
With the aerosol type, you idle/fast idle the motor and spray it right down the throttle body (I used this one)
With the liquid, you could pull it into a running engine via a vacuum line, or you could remove the plugs and put it right into the cylinders-pretty messy but some have done it (you would want to do an oil change pretty soon).
The aerosol type worked to get rid of my knock retard.
Either way, be prepared for lots of smoke the first time you drive it, LOL.
