cam install
Old Dec 26, 2001 | 05:56 PM
ls1blazer's Avatar
Default cam install
do you have to remove the heads to install a cam in an LS1?
Old Dec 26, 2001 | 06:23 PM
DR.BOOST's Avatar
Default Re: cam install
There is no need to remove the heads or intake manifold even when doing a cam swap in an LS1.
Old Dec 26, 2001 | 06:34 PM
ls1blazer's Avatar
so what ? I pull the valve covers,pushrods and pull the cam?.........a guy at the dealer said I had to pull the heads!
Old Dec 26, 2001 | 07:07 PM
11 Bravo's Avatar
Pull the pushrods out, then when you turn the cam the lifters will pop up in the holes and stay there. Then you just pull the cam out. Some guys use long magnets inside the lifter holes to insure that they don't drop in the oil pan.
Old Dec 26, 2001 | 07:13 PM
ls1blazer's Avatar
whats the procedure when adjusting the valves?is like all chevy v8's or is it different?...by the way ..that seems a little risky without the intake off!
[ December 26, 2001: Message edited by: LS1 BLAZER ]</p>
Old Dec 26, 2001 | 07:59 PM
11 Bravo's Avatar
No need to take the intake off. For the valves, I believe you just torque each rocker to a certain ft/lb. That's it. I'm sure someone here can tell you exactly. It's alot different/easier than the older engines where adjusting each valve is a pain in the ****. Someone correct me if I'm wrong.
Old Dec 26, 2001 | 09:06 PM
Tin Indian's Avatar
Lifters are non-adjustable on the LS1. You just torque the rocker arms to 22 ft lb each.
Old Dec 27, 2001 | 05:12 AM
Retsik's Avatar
Here's the nicest write-up I've found on this subject:
http://www.ls1info.com/cam_install/
