does anyone know the max lift for the ls6 springs?
I wouldn't go much higher than .525 to be on the safe side otherwise you may want a stiffer spring. What cam you gonna run?
LSX Mechanic
The 2002 Z06 cams are running a 550ish lift, so they're good for something around there.
FWIW, a buddy of mine is running a big split duration cam with the LS6 springs and spraying, no problems at all. However I personally wouldn't run an LS6 spring for a bigger cam, doubles is the only true "Safe" way to go.
Josh
Josh
