problems after plugs installed
Old Dec 28, 2001 | 09:28 PM
ROBS SS's Avatar
Default problems after plugs installed
well today i changed my sparkplugs out for some colder plugs.(for nitrous)have them gaped at .37 ,and when i put it all bact together when its in gear it wants to die, like mabe the idals to low or somthing...when it was apart i had the batterie disconected the hole time i was working on it and thought that mabe the computer reset it self and had to re-learn everything, well ive been driving arround all night and still no difference...any ideas
Old Dec 29, 2001 | 09:17 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: problems after plugs installed
Any misfires? (Flashing SES light)
You may just need to redo the idle relearn procedure. I don't have that info handy right here, you might try a search on it.
Tony
Old Dec 29, 2001 | 09:20 AM
TA_2001's Avatar
relearn..
http://ls1info.com/article.php?sid=24
and also recheck all connections..
Old Dec 29, 2001 | 03:09 PM
ROBS SS's Avatar
i did all that and same problem...just seems to ideal to low. if i just touch the gas and bring it up 100 rpms its ok....should i try and set ideal higher.....the plugs just might be to cold...i just put a new set in, thinking mabe i got a bad plug...and its doing the same thing
Old Dec 29, 2001 | 03:32 PM
LIL SS's Avatar
Moderator
Rob,
What are you using for plugs? NGK TR6, Autolight 105? I know some people have had problems with the Autolights under idle situations. I have an M6 trans and run with the autolights and they work great for me. Just another idea for you to check into
Old Dec 29, 2001 | 03:46 PM
ROBS SS's Avatar
they are autolites 103's
Old Dec 30, 2001 | 02:32 AM
ROBS SS's Avatar
come on guys i know some one has had a simular problem
Old Dec 31, 2001 | 02:48 PM
mjf454's Avatar
I had the same problem with the 103s, I changed them to tr6s and the idle is perfect and it runs great.I think the 103s are to cold for auto.
Old Dec 31, 2001 | 03:44 PM
Slowhawk's Avatar
LS1Tech Sponsor
I used the autolites-same problem <img src="gr_sad.gif" border="0">
Switched to TR6's gapped at .38 and problem gone <img src="gr_grin.gif" border="0">
Old Dec 31, 2001 | 03:48 PM
Benjamin Russick's Avatar
Yeah, I went with the TR6s and had no problems.
Old Dec 31, 2001 | 05:42 PM
ROBS SS's Avatar
yeah, thanks guys, ill be changing them shortly when i get a chance....not like there that easy to change(i hate changing plugs in this car)
