Shim kit
Old Dec 30, 2001 | 01:36 AM
AlonzoVersion 1.0's Avatar
Default Shim kit
I have the comp hammer cam and I was wondering what is a shim kit and do I need one for the install?I already have after market heads and cam springs retainers etc...Do I need this kit?Thanks.
Old Dec 30, 2001 | 08:23 AM
TA_2001's Avatar
Default Re: Shim kit
I dont know of any shims except to make the cars
idle a bit better by placing the shim under the
idle set screw size = .022 or so..
That is the only shim that I have heard of
Its My Yard....
Old Dec 30, 2001 | 06:54 PM
99 WS6's Avatar
I think you might be talking about rocker shims. I don't think you will need them, but I am not sure. I think that they are used instead of getting new pushrods. But if you have the right length pushrods you should not need them. Hopefully someone who knows a little more can help explain this.
Jeff
