symptoms of bent pushrods????
Old Jan 2, 2002 | 06:28 PM
Bad Habit Bird's Avatar
Default symptoms of bent pushrods????
ok as some of you know my car hasnt been running right lately. I got it on a scanner today to see what it was doing and here is what I found.
after a WOT run I get a misfire code on #8
I have put in 2 different sets of plugs and tried gapping both sets at different amounts so its not the plugs, I have swapped the plugs wires a few times and it still misses on 8, finally I tried changing the coils around and it is still missing on #8 above 5k.
I can hear a ticking noise that I have thought was an exhaust leak while the car is idling but from what people have said a bent pushrod could cause this noise.
does anyone have any ideas?
[ January 04, 2002: Message edited by: Bad Habit Bird ]</p>
Old Jan 2, 2002 | 06:50 PM
Will2's Avatar
Default Re: symptoms of bent pushrods????
tick tick tick = the best way to tell.
Open your engine and take a peak.
They are easy to change.
Old Jan 2, 2002 | 10:16 PM
So could a bent pushrod cause my car to do this, and have these problems? or should I look for something else?
Old Jan 2, 2002 | 10:21 PM
ExtremeZ28's Avatar
i broke a pushrod completley in half in my car and my car ran like crap was missing like a **** with the flashing SES light and everything and was WAY down on power...so i knew something was up....got it all fixed with a new pushrod and everything is good as new just dynoed 337RWHP/354RWTQ with my boltons with a smoooooth graph so i guess everything is allright <img src="gr_grin.gif" border="0">
Old Jan 2, 2002 | 11:17 PM
jimmypop13's Avatar
I'm not sure if my car has a bent pushrod or bad lifter because I've heard both. My dealer tried to tell me it was normal but turns out they just started it for a sec when it was cold and it's hard to hear when it's at that high an rpm anyway so now that I've had GM talk to them telling them it's not normal, hopefully they will fix it this time. What mine sounds like is a loud ticking that doesn't go away at idle and lately at WOT it takes a second to finally shift like it just sits there. The other day it sounded like it hit the rev limiter but it was only at 4,500 rpms. If it's a lifter, I guess it could be collapsing and causing this.
Old Jan 2, 2002 | 11:22 PM
BIGBOS's Avatar
Lots of lost power and TICK TICK TICK TICK, but thats what I heard when I busted up a valvespring under normal driving
Old Jan 2, 2002 | 11:24 PM
I havent ever heard of anyone have problems with the lifters before. but I guess its possible <img src="images/icons/confused.gif" border="0">
Old Jan 3, 2002 | 12:12 AM
TBaGZ's Avatar
doesn't the ls1 have solid lifters?......if so how could it collapse
Old Jan 3, 2002 | 02:41 PM
jimmypop13's Avatar
I'm just going by what a tech at SLP said when he heard my sound clip of it. He said it sounded like valvetrain noise like a collapsed lifter. I've also heard of a few other people on LS1.com who had some ticking so the dealer replaced their lifters and now there is no ticking so that's what I'm hoping my dealer will do now that GMs on them about it.
Old Jan 3, 2002 | 04:37 PM
well the ticking isnt there all the time though.
We checked the pushrods, springs and compression today and all were good.
Im thinking the only things left is the injector for that cylinder or the computer. Im going to swap injectors tomorow and see if the miss follows the injector, if it doesnt I am clueless <img src="images/icons/confused.gif" border="0">
Old Jan 3, 2002 | 08:25 PM
ChrisRedTA's Avatar
I had a problem like this, my car ticked like a **** ideled all shity with a blinking SES light and all, turned out to be bent pushrods and two calasped lifters. Thank god for warrenty!
Old Jan 4, 2002 | 12:12 AM
nitrousc5's Avatar
ok, here goes...first thing you have to figure out is 'what causes misfire?' a lot of things; crank trigger picking up stray signals, cam position trigger doing same, bad coil/wire/plug, carbon buildup, etc. if you've moved a set of known good coil/plug/wire over from a good cylinder, then it is possible that a collapsed lifter is not allowing proper mixture to propagate into cylinder and fire properly. the tickin you have sounds like the problem.
Old Jan 4, 2002 | 12:49 AM
so a collapsed lifter wont tick all the time? I would think it would make a lot of noise all the time and would be down on power throughout the powerband as well, and not just above 5k.
