Building a 402
Old Dec 5, 2006 | 10:32 AM
allna6's Avatar
Default Building a 402
I have very little experience with building engines and I was hoping somebody could help me with this.
What does it take to get a 3.9 bore to accept a 4.0 piston. I know it will recquire some type of boring but will a LS1 block accept this? Or am I better off buying a new block.
Old Dec 5, 2006 | 10:40 AM
GR33N GoblinM6's Avatar
no.... you cant bore the LS1... you need a resleeve or better yet... check out some of the sponsor's on the left.. such as Texas Speed & Performance.. they sell a 402ci.. damn good price as well.
Old Dec 5, 2006 | 11:47 AM
DoesSpeedTurnUon's Avatar
You can make a 402 our of an LS2 block.
Old Dec 5, 2006 | 02:32 PM
GuitsBoy's Avatar
As said already, you cant bore enough out of the stock ls1 / ls6 sleeves. You would need the block resleeved, which is very expensive. Cheapest way is to use an aluminum LS2 block, or a cast iron 6.0L truck block.
Old Dec 5, 2006 | 02:51 PM
Zach@Texas-Speed's Avatar
3.908" is probably the most you want to take your factory sleeves out to on the LS1 block.
If your wanting 400+ cubes you'll need to make a decision between the Iron block which is usually built with a 4.030" piston or the LS2 aluminum block that is usually built with a 4.005"
The Iron is less expensive by about 400 dollars or so, but you sacrifice the extra weight.
If you are interested in building a motor let me know, we have whatever you need and always have motors on the shelf and ready to ship!!
Zach
Old May 1, 2007 | 03:17 PM
maxpit's Avatar
How much would it cost to resleeve the ls1 to accet a 4" bore?
Old May 1, 2007 | 03:20 PM
pretty sure you'd be better off to buy a new block.
Old May 1, 2007 | 03:47 PM
GuitsBoy's Avatar
Yeah, the LS2 block will get you to 4"
Old May 1, 2007 | 03:58 PM
Darton resleeve kit is like $1500 + installation cost..
you can get a 6.0 block for less than the sleeve kit.. and probably find a nice short block for $1800 out of a GTO or corvette
