can you FEEL "engine ping"?
Old Jan 3, 2002 | 06:43 PM
Will2's Avatar
Default can you FEEL "engine ping"?
When I has it, as the RPM's launch, I sometimes feel a little studder like feeling.
This is only at WOT.
I have just installed a T1 cam/LS6 intake and ported out the throttle body.
How can I tell if I am rich or lean without auto tap?
The car does smell somewhat gassy sometimes as well but there is no black smoke.
Old Jan 3, 2002 | 06:57 PM
LS1powerN20's Avatar
Default Re: can you FEEL "engine ping"?
The only other way i know of without ATAP is to maybe look in your exhaust tips right after a hard run and if the inside of the exhaust tip is wet chances are you are running rich. HOWEVER, this is not always very accurate, because water sometimes comes out of the exhaust, the best way is with ATAP or some other diagnostic tool.
Old Jan 3, 2002 | 07:08 PM
Ragtop 99's Avatar
If you have any question that you are lean, get rid of the ported MAF ends until you know for sure. Me no like detonation. <img src="gr_images/icons/mad.gif" border="0">
Generally you can hear the pinging, although with a really loud exhaust you might not.
Old Jan 3, 2002 | 07:23 PM
Will2's Avatar
I have a GMAF.
Here is my sig from LS1.com
2000 T/A M6
Intake
FTRA,Direct Flow(Fram),GMS MAF,Ported Throttle Body, LS6 Intake.
Exhaust
MAC Headers w/offroad pipe, SLP Loudmouth
Engine
MTI T1 Cam, Comp Cam 941 Springs w/Lunati Titanium retainers/chromoly pushrods, ASP Pulley,
Suspension
BMR trak pak + relocation brackets, Eibach Lowering kit.
Misc.
B&M ripper, HPP3 (6600 RPM's, 160 t-stat), Decals, Cartek Clutch!
Next on my list:
Stage 2 Heads. Strange rear end w/4.11's
Old Jan 4, 2002 | 05:20 PM
Will2's Avatar
ttt
Old Jan 4, 2002 | 05:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
YOu can hear pinging... In this one car I drove, I could make it happen by practically coasting in 3rd or 4th, and then gradually rolling into the throttle... tling tling tling.
