How to tell if a con. rod is bent
Re: How to tell if a con. rod is bent
If you bent a rod, chances are your bearings are screwed and you will hear a knocking sound. Also when you bend a rod usually it takes out the block and the piston and seizes the entire motor. A spun bearing is far more likely unless you hydro locked the motor or blew something with a power adder.
Chris
Chris
