Head gasket choice poll!
Thanks
Can I just re-use stock head gaskets and bolts? Should I get new ones, what size?
Thanks.
As far as which head gaskets, I would go with .040 cometics for a tight quench if your setup allows.
We replaced them too.
here's pic of the notch. you'll see it under the third cylinder from the right.
here's a pic of the MLS gasket. you'll notice there is no sealer around the water holes. so, the water travels across the metal to the notch and leaks right out of the block.
