Oil Pressure!! WTF?!?!?!
)...my pressure dropped to 28
but jumped back to 40+ when i stared moving, ur alright
This is with 5w40 Euro Amsoil and a K&N Gold Filter.
I am to the conclusion that it is probably my OPSU. It tends to jump back and forth a little. Now while im cruising it will sit at about 37psi. This still doesnt seem right to me.
mine does the same thing...perfect at start up , but when i drive for a while and come to a complete stop, it will fluctuate in between 30-40psi. but it will return to 40psi once i give it gas.
i was told it could be the opsu, havent changed mine yet though...im also going to try thr k&n filter first to see if it helps any.
Josh
Josh
or some reason it can't get the volume of oil it need's
I put 4000 miles on it in the past 2 months. Still runs just above 40 most of the time.
In every situation it still goes to about 65 when revved.
I just had my intake off to do knock sensors and seen the oil sender, thought of changing it but didn't.
While putting the intake back on I looked real good and I'm sure the sender can be changed without removing the intake.
I'm not worried because my 1992 silverado did the same thing, I put a mechanical gauge on it and it was fine. The gauge on that would freak out at idle a lot so i changed it and it's been fine since.
If the oil pressure reads steady low I might be concerned, but if the needle jumps around it's almost always a bad sender.
