Oil Pressure!! WTF?!?!?!
Old Dec 5, 2006 | 10:06 PM
blkbird's Avatar
Default *UPDATE* Oil Pressure!! WTF?!?!?!
Ok, so I was driving in traffic to my buddies house and it was bumper to bumper. Well anyways, I noticed that when I was stopped at idle my oil pressure dropped from where it usually sits at idle (40psi) to 30psi. Now, im thinking to myself, I hope my oil pump isnt giving out. Well I get to my buddies house and look for anything unusual and find nothing. No leaks or anything like that. I replaced the oil pump with a new one when I did my cam swap in april. Could my oil pressure sending unit be going out. I have been having problems with my alternator (lights flickering) and dont know if that would contribute to the problem. Is there a different way to check the oil pressure?? Any thoughts. Im stumpped.
*UPDATE* OK. Bringing this back from the dead. My car is starting to dip as well, but only when im at low rpm in 5th or 6th gear. Other than the fact that now it idles at 18-21psi hot and bout 30psi cold start and while cruising it sits about 30-35psi. This is buggin the **** out of me!! Im gonna replace the oring and see if that makes any difference when I replace my oil pan gasket here in a month or so.....If that doesnt work, im gonna replace the damn pump again!!
Old Dec 5, 2006 | 10:24 PM
Z28LS1camaroguy's Avatar
if you sit there the oil is gonna get hot, and it doesnt flow as fast while sitting there so it thins out letting the pressure go down, mine goes down to 30 on really hot days and alot of guys on here does the same. Now if the needle flicks back and forth then the sending unit could be going out but other than that the oil pressure is fine, 10 psi for 1000 RPMs
Old Dec 5, 2006 | 10:41 PM
SuperSlow02's Avatar
change the oil..could be getting old..simple things sometimes make you freak out
Old Dec 6, 2006 | 06:20 AM
blkbird's Avatar
I just changed the oil last week.... Now when I am cruising it sits right at 40psi no matter how fast im going (in 6th gear). The needle does move a little bit when idling but I think that is the alternator doing that (bad regulator). Im still worried a little. The car still runs strong.
Old Dec 6, 2006 | 08:13 AM
blkbird's Avatar
Oh yeah, i did put in one of those new design pcv valves on there but that was also last week when I changed the oil and it just started doing it last night.
Old Dec 6, 2006 | 09:07 AM
eamador11's Avatar
Mine always did that, even stock. your fine
Old Dec 6, 2006 | 09:09 AM
eamador11's Avatar
speed wont determine oil pressure needed.
drive to 4500 rpm on 3rd. the oil pressure should rise past 40. if it doesnt you may have an issue, probably pinched oil pump O-ring
Old Dec 6, 2006 | 09:44 AM
blkbird's Avatar
OK. Once i down shift to third and get on it, it goes up quite a bit. I guess I wont worry about it too much then. I replaced the oil pump in april but it just started doing this yesterday. So I dont think I pinched the o ring.
Old Dec 6, 2006 | 10:22 AM
Billdog350's Avatar
My 1997 LS1 has 120,000 mi on it and its still getting ~47 psi above 4000rpm at 200 deg oil temps with Mobil1 5w30. I know thats a bit low, but does that sound REALLY out of line? The pump was replaced with a brand new LS6 (not shimmed or ported) one a when the heads and cam were done about 1000mi ago.
Since my new heads and cam were installed, the oil pressure has been lower (oil temps higher too)....trying to find the source. First task today is to replace the oil with 15w50 and get rid of that crappy fram and throw a baldwin in there. Too bad there is only 1000 mi on that oil!
Old Dec 6, 2006 | 10:39 AM
BLKWS.6's Avatar
My 75K Mile ws.6 gets 41-43psi heatsoaked idle (750) and 60+ at anything over 3K at WOT (it got about 2psi less with 10-30 M1 and Castrol, I am using 0-30GC now). I would keep an eye on things if I were you. Maybe its normal, maybe not, but keep an eye on it.
Old Dec 6, 2006 | 02:09 PM
blkbird's Avatar
Would it be adviseable to do a compression test. Would it be running shitty if I was losing compression??
Old Dec 6, 2006 | 02:33 PM
LostCauseZ06's Avatar
lmao these threads crack me up...
7 PSI for every 1k RPM's on LS1 engines... tighter tolerances and clearances = not so much oil needed.
unless your idling at less than 30 PSI you have absolutely nothing to worry about. especially if your oil pressure still rises with RPM's.
Old Dec 6, 2006 | 02:34 PM
btw my 408 idles at 34 PSI
Old Dec 6, 2006 | 02:38 PM
blkbird's Avatar
Yes, but what would cause the sudden drop in pressure?? This is what im really asking.
Old Dec 6, 2006 | 02:42 PM
66deuce's Avatar
mine idles at about 22psi.never had a problem...
Old Dec 6, 2006 | 03:05 PM
parts wear and stuff wont be as tight in the motor, engines get old so theres nothin you can do about that other than rebuild it.
Old Dec 6, 2006 | 04:31 PM
the pressure drop could have been anything... could be the sensor... could be that the oil got hotter that day, could be it had hit a "thinning" point in the oils life...
the point is that if your pressure rises with RPM's then your pump is working. if you have good oil pressure at idle and it raises to good oil pressure at WOT/high RPM's then you have no worries..
if your still worried about it then go buy a mechanical gauge and check it manually with a aftermarket gauge.
Old Dec 7, 2006 | 07:39 AM
Billdog350's Avatar
I changed out the fram that was on there after reading about how badly they flow. Threw on a baldwin since they are rated pretty highly. Pressure jumped 5 psi at idle and 15 psi at 5000 rpm. Car is now 65psi at 5000 rpm and 35 psi at idle. Sounds like it isn't as worn as I thought!!!!
Old Dec 7, 2006 | 10:49 AM
eamador11's Avatar
Nope your fine, im 210 oil temps. if the needle didnt rise past 40psi when your RPMs climbed, then you have a problem.
Old Dec 7, 2006 | 10:51 AM
eamador11's Avatar
Nice...thats why I stay with AC delco filters, cant go wrong with OEM
