320hp, 343tq, good numbers?
2000 Z28 M6
Mods:
SLP LT's with ORP
Borla wide open
FTRA
Direct flow lid and K&N
Whisper MAF ended, descreened and ported MAF
Cut EGR tube
ASP UD pullies (crank and alt)
[ January 05, 2002: Message edited by: FastAl ]</p>
If you can, scan in a picture of your dyno sheet so we can see if anything looks out of the ordinary. Plus we need to see what RPM the guy took the car up to on the dyno. It is best to hit the rev limiter sometimes on the dyno to make sure you rev the car to the correct max HP range.
Dan
If so, those are good #s <img src="gr_stretch.gif" border="0">
Dope
<strong>I'm pretty sure Bandimere is at really high elevation. Something in excess of 5000 feet?
Dope</strong><hr></blockquote>damn i didn't notice where he was from but if the elevation is that high then you are correct those are good numbers then
[ January 06, 2002: Message edited by: Red Dragon ]</p>
<strong>I must have dog too 326 rwhp. 332 tq. That was with TTS lt's, GMAFS, DIRECT FLOW lid & running a 13.4 a/f. without any kn. Someone tell me what i'm doing wrong.I ran a 12.90 @111.84 (2.12 60ft). I feel it has more hp. than it shows because of the trap speed. The 60 ft.sucks,i know. Just like FastAl i'm looking for some answers, Thanks BOB</strong><hr></blockquote>
Your A/F of 13.4 is within normal limits, but could probably be richened up a bit. Shoot for 12.7 - 13.0 for max hp.
So anywhere in between should be the premo setting...of course not all cars respond exactly the same.
<strong>CARLITOS, I'v run 5% richer& it raised my et.s & lowered my mph.It runs .890 o2's now. BOB
[ January 06, 2002: Message edited by: Bob Neese ]</strong><hr></blockquote>
Did you by any chance change the settings just prior to a run or in between two back to back runs? If so, that could be why you slowed down. Then again, your car may just be an exception. What Dan posted is typical optimum A/F ratios.
[ January 06, 2002: Message edited by: Bob Neese ]</p>
<strong>Ok while I'm happy with the way my car got tuned up today, I'm still a little surprised at the low horsepower number. It was tuned on a dyno using a MAFT to get a good A/F ratio. So do my numbers sound good for what I have? The car was fairly running pretty rich before the MAFT adjustments! Best 1/4 at Bandimere is 13.8@104
2000 Z28 M6
Mods:
SLP LT's with ORP
Borla wide open
FTRA
Cut EGR tube
[ January 05, 2002: Message edited by: FastAl ]</strong><hr></blockquote>
Did you dyno at Dyno Pro in Denver. That was where I did mine. Maybe it's that dyno?
The offical altitude for Bandimere is 5800 feet <img src="gr_grin.gif" border="0"> Normal density altiude is closer to 10,000+ feet!
