HELP ASAP!! Oil pan problem
Old Dec 7, 2006 | 12:44 PM
Blk97WS6's Avatar
Default HELP ASAP!! Oil pan problem
hey everyone,
im trying to drop the oil pan some to do an oil pump swap. ive loosened all 10 bolts around the perimeter, but the damn thing wont budge at all. ive tried prying it, and hitting with a rubber mallet. it wont drop at all. are there any bolts that i missed? im sure ive got all of the around the perimeter. do i need to take out the bolts that come from the bellhousing into the oil pan? whats the deal? thanks for any help!
-Derek
Old Dec 7, 2006 | 12:52 PM
V6 Bird's Avatar
Originally Posted by Blk97WS6
hey everyone,
-Derek
You just answered your own question at the end of your statements.
Old Dec 7, 2006 | 02:40 PM
Blk97WS6's Avatar
yup, went back outside took those out and it dropped right down. thanks
Old Dec 7, 2006 | 04:24 PM
2000Hawk's Avatar
Don't forget to put them back in when your putting things back together. Also don't tighten things to much either on the oil pan, use a torque wrench if you got one.
-Joel
Old Dec 7, 2006 | 11:52 PM
Blk97WS6's Avatar
^^^i do have a couple torque wrenches and ill be tighning EVERYTHING to specs. thanks for the help. now on to the damn pick-up tube bolt.
Old Dec 8, 2006 | 12:28 AM
erikthegoalie's Avatar
i put my oil pan back on tonight...along with some RTV sealant....I did not use my torq wrench...but I basically made them all snug....good enough for me
as far as the pick up tube bolt goes...check this out..i got a closed end 100mm "ratchet" wrench....i dabbed some grease on the head of the bolt and stuck it in the wrench (so the bolt would not fall out.....i postioned it with the wrench, and with a pair of needle nose pliers I slowly turned it into the hole...worked like a ****!
good luck man
Erik
Old Dec 8, 2006 | 01:38 AM
Blk97WS6's Avatar
^^^nice! definetly worth a shot
Old Dec 8, 2006 | 02:44 PM
Blk97WS6's Avatar
hey erik
your a genious man, used that approach you told me about, got it on the 2nd try! thanks man you just saved me at least a 1/2 an hour!
Old Dec 8, 2006 | 06:56 PM
Mssingkid's Avatar
To reinstall the bolt, i tied some thread around the bolt in case it fell. Sure enough i dropped that thing many times but it never got far enough away that i couldn't just pull it out. Once you've got the bolt started, give a hard yank and the thread should break.
Old Dec 9, 2006 | 06:47 PM
hazard2k's Avatar
That damn bolt! My most recent cam install I did i stuffed a few rags right in the oil pan so when the bolt fell it couldnt go anywhere. It worked out VERY nicely. Although the first time doing one i dropped it in the pan.. Big mistage. I had to go fishing for quite some while. Heres a tip.. Put a magnet in the end of some rubber hose. The hose is flexible enough to move around objects, but stiff enough where you can direct it around a little bit. Worked good on getting that bolt out of the oil pan... Good luck with the build!
Old Dec 9, 2006 | 07:12 PM
MiaSSmaro98's Avatar
good luck man
Erik
ERIC WHY DID U HAVE TO DROP THE PAN?
Old Dec 9, 2006 | 11:21 PM
Hey buddy anytime...glad it helped!! My dad has taught me all these tricks with nuts, wrenches and grease in tight spots hahaha so, I applied..
Old Dec 9, 2006 | 11:22 PM
Hey buddy
You have to drop it to disconnect the oil pump pickup tube from the pump..so you can replace it with a ported pump...which I did...a real PITA..but its ok...ill have BAD A oil press!
Erik
Old Dec 9, 2006 | 11:41 PM
Cop Car's Avatar
another solution to the oil pickup tube problem would be to put a piece of tape on the end of the boxed end wrench.
as for the oil pan, make sure you follow the sequence, and keep on going around and around, because it does make a big diffrence. if you put it in a bind it WILL crack and its not cheap to replace
Old Dec 9, 2006 | 11:49 PM
Blk97WS6's Avatar
well i successfully got the oil pan back on today before i went to work. tomarrow im going to try and tackle the springs. wish me luck!
