Input needed....cam with springs
Old 12-08-2006, 05:59 AM
staringback05's Avatar
Default Input needed....cam with springs
just wanted to see if anyone had ran a 224/224 112 cam with 03+ ls6 springs? if so what were the results?
Old 12-08-2006, 06:34 PM
Ls2Sonoma's Avatar
springs have a lot to do with lift.....
Old 12-09-2006, 06:48 PM
hazard2k's Avatar
I am running a TR224 and put on some comp 918's. Worked out great! Not sure on the specs of the ls6 springs, but I would imagine they are not as good as the comp's.
Old 12-09-2006, 11:34 PM
1997bird's Avatar
How much lift is your cam? Just courious, needed info for the proper spring pressure.
The ls6 spring has 90 lbs @ 1.8" for the seat 280 lbs @ 1.2" for the open pressure.
The 918 spring has 130 lbs @ 1.8" for the seat 333 lbs @ 1.15" for the open pressure.
Also do you have the hollow stem valves from the 02'-04' Z06?
