?'s from Chevy High Performance Magazine
1) Engine coolant temperature (ECT) sensor readout / fan control switch - This would be a 2 part article that first introduces the reader to the sensor and how it works then provides a circuit that lets the user accurately read the coolant temperature using a digital multimeter (or separate meter). (The F-body LS1 temperature gauge is inaccurate as you all know.) The second part of this article will show how to adjust when the low speed fans turn-on and turn-off. This circuit lets the user change the thermostat and control when the low speed fans come on and off with out buying an aftermarket programmer (e.g. Hypertech).
2) Oxygen sensor simulators - This is good for OBDII people that have removed their cats and do not want to throw any codes. I have designed an oxygen sensor simulator that is relatively easy to build. The cost is much less than the $100-$150 for ready-built simulators.
3) How to measure aerodynamic drag and rolling friction - Not an electrical article but very useful information.
4) Product review - Speedometer recalibrator - This could be a controversial topic. The calibrators are useful for people that have
changed rear end gears and want the speedometer and odometer to read correctly. I would compare the Cyberdyne and SLP models. I have the Cvberdyne speedometer calibrator and I have found a couple technical problems with their unit. I have fixed their design by changing a couple of components.
5) Product review - Mass air flow translator - This helps tweak the timing and the WOT A/F ratio. A description of the MAF would be given and how it interfaces with the PCM. I would review the RamChargers and the Granatelli versions.
The intent is not to turn the magazine into Popular Electronics, but provide more rounded high performance articles by discussing the electrical side too.
Hey where would i send a writing sample?
Ryan
Brandon
a header comparo would be top on my list also.
tire comparo-ir nitto DR, bfg DR, ET Street, vs. standard radial tire.
a good detailed article on autotap with what parameters to look at and how to log etc.
weight reduction article
a comparo that would settle all ? on the issue of camaro vs SS vs ta vs WS6
[ January 08, 2002: Message edited by: Nickn20 ]</p>
A LOT of people are always asking for a comparison between different longtube setups.
Daniel
The Underdog - You can e-mail your ideas/letters to chevyhi@emapUSA.com Provide a short summary of the article you would like to author.
I'm trying get the magazine to recognize us. It seems that most of their background lies with the older stuff. I keep telling them that carbs are for lawnmowers.
I'd like to start with relatively "easy" articles (i.e. low budget) so that I don't scare the editors or the readership. That is why I suggested the articles above. Once we get some momentum going we can move into more detailed technical stuff like LS1 edit, etc.
Please keep the suggestions coming.
Looking forward to seeing some of the "Board Guys" in your Mag!
Taco
Ryan
An article on how to perform an Autotap on an LS1, logging the results, and adjusting the car for optimum performance. Many people could gain from this since information on how to do this well is not exactly widespread.
The LS1/LS6 is quite a powerful engine that takes to modifications well, but is still feared by some of the community as being too complicated, particularly with the factory FI harness and associated controls. Any article that could help dissuade that and show the engine's potential would be great.
<strong>Wow! Thanks for the responses.
Please keep the suggestions coming.</strong><hr></blockquote>
And i know this is a predomenitly F-body forum, but how about doing more stuff that is "common" to both the F-body and the C5. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
LS1 stuff applies to us too and with the demise of factory installed LS1's into F-body's where do you think the next biggest market in the future will be for LS1 performance......(hint: retro-fitting <img src="gr_grin.gif" border="0"> )
[ January 08, 2002: Message edited by: John B ]</p>
baker hose/fernco hose vs OEM hose.
OEM MAF vs Pace LS6 MAF w/LS1 calibrations.
basic stuff, like that with data. Unbiased.
